Piranah bar kicks arse.....
   / Piranah bar kicks arse..... #22
It's been 4 weeks and still no bar shipped. Customer service fone is not answering.
   / Piranah bar kicks arse..... #23
Maybe I'm not doing things right, but I'm not able to clear underbrush like you all are. It just seems to push things over, but not tear anything out. It does seem to work better if I have some heavy ballast on the back. I have a bx2380, with r4 tires.
I am new to the fel, my old Kubota didn't have one.
Any tips?
   / Piranah bar kicks arse..... #27
Any tips?
First job with the Piranha I cleaned about 80' of blackberry vines with some small trees grown up in the middle. There is a definite learning process. I managed go get one 4" diameter maple up by digging in from all four sides and then backing up a couple feet and ramming under the tree. Then wiggle the front of the bucket with the curl. Took a few minutes but finally tore the tap root and up it came. The vines were removed by scooping an inch or two under ground and doing the same wiggle. The job took two days and I did twice the work in half the time the second day after I learned a little.
RSKY
   / Piranah bar kicks arse..... #28
I can catch and pull out 4 inch osage trees no problem, The honey locust is a different story , have to dig them out. Last week i pushed over a 10 inch pine and popped the root ball right out with the pirrahna. love it.
   / Piranah bar kicks arse..... #29
I've got a 55hp utility tractor with a 48in grapple. Will I benefit from one of these too? I was considering one just for a little extra digging/cutting in with the bucket
   / Piranah bar kicks arse..... #30
Unless you have large machine buckets don't dig well, and compared to a toothbar, piranha works much better
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
Mower King Brush Cutter (A53317)
Mower King Brush...
2003 Big Tex 10PI...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
