Pipe jacks or whatever else
/ Pipe jacks or whatever else #1
jw3
I was in the shop this evening and had to move them put of the way. Thought y'all might get a kick out of them. I know that this something I could've bought, but none of my lws are open normally we I need them to be. The shaft is 1" allthread , the legs are 1 1/4" sch 40 pipe, and the body is 2"X2" sq tube. So far they have worked well. I might have to buy a store bought one to compare it with one of these days.
/ Pipe jacks or whatever else #2
I'd take those Jacks any day. Could have used them on my Outdoor Wood Boiler Pipe Extension. I ended up using channel laid out on my welding table. Jacks would have been much easier. :thumbsup:
Necessity is the mother of all invention
/ Pipe jacks or whatever else #4
I bought a pair from HF. I would have made them but I didn't have the lead screw or the bearing. I needed a set for under my 2 post car lift so the ones I got go up to 8' high. But that means they only go down to 4', a little high to use for other shop projects so I may follow your lead and make another set and just transfer the lead screw from one to another. Nice job.
Crazy Al I didn't use any bearings. I'm in the plumbing business so I keep all my drop pieces of black iron for projects and such.
/ Pipe jacks or whatever else #7
Jack stands are as handy as a pocket on a shirt;). I've made several, and bought a few.
/ Pipe jacks or whatever else #9
I used to build some really big gates that were a bit longer than my 20' table would handle (up to 54') and adjustable stands worked fine for keeping everything straight and level.
/ Pipe jacks or whatever else #10
A friend who owns a sprinkler business made some using steel wheels from a car as the base and two pieces of pipe, one slid inside the other with a nut welded to the outside of the outer one and a bolt to tighten it up.
1997 Ford Expedition 4X4 SUV (A66738)
1997 Ford...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2021 CHEVROLET SILVERADO 3500HD SERVOCE TRUCK (A67714)
2021 CHEVROLET...
2012 . Tri Axle Crude Trailer (A67714)
2012 . Tri Axle...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2006 HEIL MC407 (A67714)
2006 HEIL MC407...
