Pinning up MMM tricks?
/ Pinning up MMM tricks? #1
Will
Athens, Georgia
B2410HSD
Does anyone have any tricks for pinning up a MMM on a B2410? I've got the mower adjusted so that pin holes almost line up when I lift the 3 point hitch all of the way, but it is still a pain in the neck crawling around on the ground with my arm under the tractor trying to plug the small pin in that holds it up. Even worse is trying to line the spring clip up with the hole in the pin and attach it by feel. Has anyone figured out a better technique? Or has anyone found/made a pin with a handle to hold up their MMM?
/ Pinning up MMM tricks? #2
No--I know of no tricks other than trading for the BX which has a knob that adjusts for height and also locks the deck at the top without those stupid pins. I assume you have the FEL which makes pinning the deck more difficult because of the FEL arms you only have rear access. Mine do not quite line up either on full lift and I went to the dealer and looked at a 7500 and they do not either. It requires a slight lift to get the pins in--easy enough but pinning the pins with the clip--especially on the right side is a pain. Oh well. I put a cross mark on my pins so I could see the hole alignement. I am going to look for some push type pins that have the thumb release--those would cure the problem.
While I was there a new 7500 was getting scrubbed for a customer delievery--what a sweet sounding little engine. J
/ Pinning up MMM tricks? #3
Will, Attached is a photo of the pin I made for my 72" MMM on my B2710. It slides thru both holes and its easy to put the pin to hold it in from the out side. Feel free to copy this design, I got the idea from someone else on TBN!
/ Pinning up MMM tricks? #4
That is a great idea for the larger 2710/2910 but alas it will not work on the 2410/7500. The reinforcement brace for the FEL mount obscures the holes. It might be reasonable to remove approx 0.3 to 0.5 inches of material in a half moon shape from the triangular brace with out affecting the integrity of the unit and then the one piece pin would be able to slide all the way through. J
/ Pinning up MMM tricks? #6
Don't understand why they even put the brackets on my 2910 if the lift won't get it high enough to pin it when not in use. Major disappointment with Kubota engineering! About the only thing I don't like about the tractor, other than the trash in my fuel tank on delivery.
Have just decided I must tolerate it - When I finish mowing many times I have other uses for the tractor that requires the deck be pinned up. For now I just jack it up with floor jack and pin it. No FEL on my tractor. If anyone comes up with a solution I would like to know.
/ Pinning up MMM tricks? #7
You need to make some adjustments to the lift rods. You should be able to raise the deck high enough that the pins can be inserted with only a minor struggle--a floor jack is a major struggle. My 2410 was way short when I first got it but then I decided the book wa full of malarky and got out the wrenches and went to it. It now raises enough that with hand pressure I can rock one side up and pin it and then the other. I am only about 1/2 hole off or even less. J
/ Pinning up MMM tricks? #8
There is a pin we use in aviation that has a thumb release that pushes a rod that retracts two small ball bearings on the other end. To insert you push the thumb release and vice versa to remove. I just have not had time to look for one and I CAN pin my deck. I think grinding off some material from the angle braces might be the best solution so as to use the full length pin. J
/ Pinning up MMM tricks? #9
I copied Von's rod for my 2910 mmm. It works well as long as the holes line up, which is not a common occurrence. I usually just take the mower on and off every week.
/ Pinning up MMM tricks? #10
My life is simpler now thanks to you. The book is malarky. I adjusted and now can pin by hand with only " a slight struggle"
Many thanks/
/ Pinning up MMM tricks? #11
I had to slightly adjust my 2910's deck but it lines up perfectly, no struggle required. I do like the long pin idea, it is something I had been toying with myself.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2015 Toyota Tacoma Ext. Cab Pickup Truck (A61573)
2015 Toyota Tacoma...
Patterson water pump (A59230)
Patterson water...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
