Pine Tar Removal
   / Pine Tar Removal #1
Bob_Young
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Spent 3 days using my L4300 hauling white pine boughs to a burn pile. Ice stripped them off the trees last winter. Now the controls, fender tops, and about anywhere else I touched is smeared with pine tar.
Does anyone have a trick or procedure for cleaning off the stuff? Seems like I saw one posted here before.
Thanks.
Bob
   / Pine Tar Removal #4
Bob:
If it were me, I would think of the pitch as protective coating.
Steve
   / Pine Tar Removal #5
Willl said:
Engine degreaser works great for anything gummy or sticky.
Excellent for removing sales tags and labels.
Makes what once was a frustrating chore a snap.
I get better results with it than I do with WD - 40.
50 chevy 60 chevy Bx23
MY FIRST CAR http://chevy.tocmp.com/chevyscrapbook/files/kamp50.jpg 1950 Chevy
OUR FIRST CAR http://www.hubcapcafe.com/i/2001/storycty/chev6001.JPG 60 Chevy Impala Convertible front http://www.hubcapcafe.com/i/2001/storycty/chev6001a.JPG rear view
MY TRACTOR http://www.jenningsequipment.com/storepics/ksBX22.jpg BX23
   / Pine Tar Removal
Thanks, guys. There's WD40 and maybe some degreaser around here. I'll try those first.
SFish: Can't leave it on. Picked the branches and limbs out of an area that was loaded with poison ivy. Made it through first contact OK by showering each night with laundry soap. Got into trouble a week or so later when I tried to re-use the tar coated work gloves.
Bob
   / Pine Tar Removal #7
Don't laugh but try baby oil, it works to take pitch off your skin, might work on other surfaces too.
   / Pine Tar Removal #8
try goo-gone. It's sold in the paint section of walmart.
home depot and Lowes also sell it.
   / Pine Tar Removal #9
Also try raiding the medicine cabinet and the garage for rubbing alcohol, lighter fluid, acetone, paint remover, gasoline etc.
   / Pine Tar Removal #10
I tried goo-gone but I went back to engine degreaser because it works as good or better than goo - gone and you get a lot more ounces of degreeser for less money than goo-gone.
2012 RAM 5500 (A52472)
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
New Idea 6254 Round Baler (A50774)
New Idea 6254...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
