PIN - 1" dia - 3-5/8" lg capture min
   / PIN - 1" dia - 3-5/8" lg capture min #1
bearthebruce
Platinum Member
Property is in Floyd County VA
'05 Massey Ferguson 1533; '22 LS MT125, '23 Kubota SVL65-2
I lost one of these pins:
For the moment, this is working:
Any one have a source for the pin lost?
   / PIN - 1" dia - 3-5/8" lg capture min #2
mcmaster carr
   / PIN - 1" dia - 3-5/8" lg capture min #3
ive seen those at tractor supply
   / PIN - 1" dia - 3-5/8" lg capture min #5
On my machines, those pins tend to get plucked off by the stuff being manipulated, moved, or clamped. I now use Cotter pins rolled around the cylinder pin.
   / PIN - 1" dia - 3-5/8" lg capture min #6
Very dependent on pin size and configuration. When I lost a pin no one (not Kioti, not TSC, not McMaster-Carr, not Amazon, not eBay, etc) had the exact pin size/shape I lost. I finally got a metal detector and spent 3 days combing the acreage where I knew I lost it. Finally found it.
I've done what I can to make sure it won't accidentally come out again.
I am missing something. What is the problem with the replacement pin?
Nothing Doug. Works fine... but I only have that one. If I lost it once, I likely am gonna loose it again. So I am looking for a place to buy some.
What bothers me the most is the manufacturer does even have stock of the pin they supplied! Wut? Yeah... I fear finest Chinesium.
I have looked at Tractor Supply, at McMaster, and other Ag supply houses and have yet to find the pin that was supplied with the grapple. So I thought I would ask..
Thanks for all the input. This old engineer will find a solution he can buy.
   / PIN - 1" dia - 3-5/8" lg capture min #9
The manufacturer probably doesn't stock it because it's easily replaced. It doesn't matter that the retention type be the same. If you're having problems with the brush taking your pins, which is certainly possibly on a grapple, you can replace them with a grade 8 bolt and nylock.
   / PIN - 1" dia - 3-5/8" lg capture min #10
You dont need the exact one, one with removable pins on both ends. The one you replaced it with will work just fine.
6.25 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
6.25 In Heavy Duty...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
SKID STEER BUCKET (A58216)
SKID STEER BUCKET...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2018 Dodge Ram 3500 (A57148)
2018 Dodge Ram...
GRAM HOME 5 SHANK CHISEL PLOW (A52708)
GRAM HOME 5 SHANK...
