Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,051
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We've got a ventless fireplace. I use a 100 lb tank outside. In the spring, I move the tank away from the house (eyesore for the wife) and put it in the woods with some other stored things.
I have to wrap up the connections that screw into the tank or the bugs will build a home inside the tubes.
Come along fall, I reconnect everything BUT.... over the prior 6 months, virtually all the propane that has been in the line has disappated.
What happens is I connect the tank back to the line, open it up. The line is full of air and then gets put under pressure when the propane line opens.
I go inside and have to purge a lot of this air before I can get my pilot light lit. It can take 10/20 minutes of fiddling before I can get it lit. Once I get it lit I never have this problem for the rest of the season. I might add that we do not leave the pilot light on, we kill it 100% and have to relight it every time we use fireplace. We do this by choice to simply not burn up gas with the pilot light. The fireplace gas supply is turned 'off' during this down time.
Here's my question: When I'm trying to purge the air from the line is the air slowly purging if I simply push & hold the pilot button in or do I need to push/release/push/release the button?
If I can simply hold it in.... it seems I'd have to hold it for 10/15 minutes.
Is there a different way to purge the air out of the gas line leading from outdoors to the fireplace?
I might add.... this is currently a moot point since I went through this last night but it drove me nuts having to fiddle with it that I finally decided I'd ask.
