Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,701
Tatch all carrier? Did I inadvertently copy something that exists?:laughing:
I'll post a picture of the linkage when I'm back on the computer.
Airbiscuit wrote something and the word 'Attachment' in his comment was darkened. Click on it and it brought me to a website with an attachment that looks very much like what you created. I thought that part of your setup was store-bought
   / Pictures of your snow weapons #5,702
The Tach-all carrier is supposed to lock in via a lower pin. I don't see an attachment point on you Box. Do you just grab under the upper hooks and let the box pivot on that?
As promised Tony.
These are without the tractor in the way but not being painted does not help the view much.
DSCN9358.jpg DSCN9363.jpg DSCN9398.jpg the other side is the same.
Open & closed or locked and unlocked
I didn't want the cylinder oriented vertically, thought it would be prone to damage and just look goofy sticking up in the air. It was a head scratcher (for me) to have a vertical "pinning" action as a result of a horizontal motion.
I can switch side without leaving the seat.
   / Pictures of your snow weapons #5,703
I wasn't trying to link to anything. I was just referencing a q..ick at..ch system that wasn't SSQA. It is a clever design and I could see it used as a universal attachment system for other attachments.
   / Pictures of your snow weapons #5,704
It works for my purpose, but it's got it's shortfalls. I could see bending of distorting the lower pins if I jammed something hard while pulling (forward). Pushing (reverse) it's fine because it's up against the framework or the tractor side of stuff. In a dirt situation the pin "receiver" could fill with dirt. I tend to use what I have on hand if I can make it work reasonably. Simulating the "euro" design that most of the world uses on buckets, forks, etc. would be much better.
   / Pictures of your snow weapons #5,705
As promised Tony.
View attachment 677363 View attachment 677364 View attachment 677365 the other side is the same.
View attachment 677366 View attachment 677367
Pretty slick Eric !!
gg
   / Pictures of your snow weapons #5,706
Ahh, I see the vertical attachment now.
A nice couple of pivots to get you from horizontal piston to vertical pinning. Your original pics had the attaching mechanism looking very must like the accidental Link. Really nice gussets on the inner angles. I used to have access to big steel. Now I struggle to find bed frames for my tinkering. Trying to make dollies for my V plow and FEL bucket. At about 1000lbs each, I need 'real' metal. Thanks for the clarification. Nice job
   / Pictures of your snow weapons #5,710
FUEL PUMP W/ NOZZLE (A58216)
FUEL PUMP W/...
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2019 Ford F-150...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A58214)
2013 POLAR TANK...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
