Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,711
cat fever: Very nice setup Lynn!
What size (diameter) hydraulic hoses run from your HP24 to your blower? Roughly how long are they? Does Erskine provide guidelines in their documentation?
Reason I ask is I have a older setup that was marketed to wood splitter users. It uses a 21 gpm Prince pump. I swapped out the valve for one intended for hydraulic motor direction control. I believe my lines might be a bit small.
1" hoses. Erskine provided everything that was needed. Except the hydraulic fluid.
   / Pictures of your snow weapons #5,712
Here痴 my receipt. View attachment File Nov 19, 4 03 07 PM-1 copy.pdf
It痴 84? I opted for rubber edge and steel on back drag. Then changed my mind and ordered a poly edge. Probably going to put that on back drag for this year. I do residential plowing in subdivisions so I知 hoping the rubber and poly are nice and quiet at 3am. I will update as I use it. A couple of concerns may be my lack of traction with R-4痴 but I want to try this year and probably groove over the summer. To many nice sealed driveways to chain up.
   / Pictures of your snow weapons #5,713
I’m on my iPad so all kinds of strange characters. I’ll respond in am from computer so those will go away. 84 inch.
   / Pictures of your snow weapons #5,714
I don't know if you've used a pusher before, but they defy physics with how much snow they can carry!
Nice rig pokey, hla makes nice stuff.
Thanks I have not. Always used plows.
   / Pictures of your snow weapons #5,715
In West KY actually global warming has become our snow weapon by default. That was not the case 60-65 years ago. It has been several years since I've pulled off the bush hog and put on the grader blade.
   / Pictures of your snow weapons #5,718
Looks good.........
   / Pictures of your snow weapons #5,720
Added some flashing LED's to my snow weapon today.
Nice install. I've wanted something similar, but I have less than 1" clearance on the roof to get my tractor in the garage.
I have a magnetic xenon strobe that I slap on the rear implement that fires once per second. The rate is slow, but it is surprisingly noticable!
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A57024)
Greenworks...
