pickup truck size
/ pickup truck size #401
It still amazing that the $20k hybrid was getting 44 mpg in that video.
/ pickup truck size #402
The amazing thing is once priced, they all cost about the same. I haven't checked on the newest models, but last I shopped pick-ups, they also all got about the same mpg regardless of size.
Isn't the maverick considerably less expensive?
/ pickup truck size #403
It depends on what you get. Base price is about 20k, but if you want an all gas engine with 4wd the price goes up accordingly.
Just like the base price of a 3/4 ton 4x4 pickup is around 37k (or was last year when I was truck shopping), but some people "need" all sorts of fancy crap which adds to the price yet doesn't make the vehicle go one foot farther before wearing out.
/ pickup truck size #404
Go to Ford and build one to see for yourself. I pretty heavily optioned a Maverick Lariat for under $34,000. My 2018 F-150 XLT sticker was just over $44k and not nearly as nicely optioned. I don't have memory seats, sunroof, automatic HVAC, Sync, adaptive cruise control, or navigation.
/ pickup truck size #405
Regardless what a person's needs are, it is nice that there are options across the truck spectrum now.
/ pickup truck size #406
My build-to-order 2011 F150 stickered north of $51K in the day before I added more aftermarket stuff. I would have liked a Platinum trim, but not with the painted bumpers that dissolve in the salt belt, or the 20" wheels that just ride poorly on frost-heaved roads. As a result, I basically made a Platinum out of a Lariat. Ten years on and I intend to continue to drive it into the ground as I just replaced the timing chain, phasers, guides, cam solenoids, all four Oxy sensors, and since the rear differential was in process of shelling, I swapped in a new Eaton TrueTrack differential carrier this summer. Considering how much ice we have the TruTrack may turn into a mistake, but at least I'll never need to change the differential oil unless servicing the axle seals or bearings. Sadly, the outer tin on the cab corners is rusting as is the lower parts of the bed. When that gets bad, I intend to bolt a flatbed on.
And all of this because the new trucks don't really offer any new features or anything I find compelling to jump on a new truck.
However, if somebody can make a reliable towing-capable EV truck, that can function well enough in our winters, I'd take a look at purchasing one.
/ pickup truck size #407
I'm currently driving a 2019 RAM 1500 Laramie I picked it up this spring when I traded in my 2015 with 98,000 miles as it was going out of the extended warranty. One reason for me to get another RAM was the availability of the extended warranty that works at any RAM dealer, I opted for the 8 year 125,000 mile one this time. Unfortunately the 8 years is a bit of fancy footwork in the naming as it's 8 years from when the vehicle was first sold but I am covered till Feb of 2027.
I never used to worry about this as I did all of my own work on my vehicles but it is getting more difficult to do as I get up in years,
heck a 4 corner brake job used to be an easy afternoon, now it takes me the afternoon to one axle. Not being physically able to do the work is quite aggravating to me. I'd much rather do it myself then take it to some parts changer, heck I still get upset with the service manager when I tell them whats wrong and what it needs and he starts his spiel that they will have to put it on the computer and see whats wrong before anything else.
The last three little things my RAM's have been in for I told them the issues and what it was and they wouldn't even order the parts till it was in the shop and then having to wait for the parts.
/ pickup truck size #408
Yeah but in all fairness to the service managers, for every owner like you that knows what he's talking about I guarantee there's 99 customers that don't know diddly.
/ pickup truck size #409
My build-to-order 2011 F150 stickered north of $51K in the day......... since the rear differential was in process of shelling, I swapped in a new Eaton TrueTrack differential carrier this summer.
Just curious/nosey ME... how many miles did you have on the OE diff ?
Did you do a lot of heavy towing/hauling ?
Rgds, D.
/ pickup truck size #410
Miss my ‘81 F150 single cab 2 wheel drive, 300 ci 6, Longbed; vinyl bench seat, crank windows, blk. vinyl floor, that I bought used in ‘85 for $2500 bucks & had for almost 18 years. That was one tough,no frills work truck !!! Ended up selling it for $1000 bucks.
/ pickup truck size #411
What a ripoff ! ;)
Even allowing for time-value-of-money, I don't think I could buy a hamburger/week today for your In/Out $ on that truck....
Drove a slightly earlier version of that truck on my friend's farm, 3inTree. Tough truck, that was beat on just about every day. That engine is still today, one of my favourite work-truck engines.
Rgds, D.
/ pickup truck size #412
We don't remember the gadgets, frills, and do-dads but we do remember and miss trucks that offered great dependability and easy-to-use simplicity.
/ pickup truck size #413
I went from a ‘84 reg cab long box to a ‘94 reg long to a ‘04 crew cab short. (6.5’) Ordered my next truck in May, expected delivery in 2023. The next one will be smaller, ext cab 6’ box. The amount of times I need the load capacity or the larger bed size is limited, it would be cheaper to run a smaller truck and use my trailer when needed.
/ pickup truck size #414
The truck I miss the most is the second truck I owned, a 1966 Chevrolet 3/4 ton with a 292 ci and 4 speed with granny gear and 4:10 rear. It wasn't fast but it was STOUT, I have regretted selling it everyday since.
/ pickup truck size #415
..Drove a slightly earlier version of that truck on my friend's farm, 3inTree. Tough truck, that was beat on just about every day. That engine is still today, one of my favourite work-truck engines.
Rgds, D.
I was going to post, GM made a similar engine in durability and fuel efficiency that few knew/know of, but John0829 already did. Many people aren't as familiar with GM's version because it was shadowed by the GM350 which had the most popularity by far.
/ pickup truck size #416
In 1979 my brother bought a new F150 base truck, i.e. 300 cu in in line 6 with manual transmission for use on the farm and pulling a cattle trailer. It was cheap but within a year it had lots of issues so my brother traded it for a slightly used 1980 Chevy 1500 with the inline 6 and an automatic transmission at that proved to be very durable. I think he only put about 88,000 on it in the approximately 10 years he had it but they were hard miles - a lot of pasture driving, short trips, pulling tractors and semi-trucks to start them (we had some of those hard starting 30 series JDs). If it did leave the farm for more than to run to town to get parts it was probably pulling a 35 ft trailer loaded with cattle.
The point is that even though they seemed like almost the same truck the way they were equipped, they were totally different in capabilities and durability.
/ pickup truck size #417
We had a 87(?) f-150 with the fuel body injected 302 V8. It had 2 fuel tanks because, well, you need them since mileage was so bad. I swear you can see the fuel gauge going down. So little power, I thought we couldn't get up the hills we have here. Not at all comfortable to drive and sit on its bench seat that we wouldn't drive it to the nearest city 100 miles away. It was 2 wheel drive so we only used it in the summer but when they forecasted snow, it would start to spin when it heard that.
Glad to see it gone. You couldn't pull our 2019 ranger from our cold, stiff fingers with its 260+hp. Oh and it gets twice the fuel mileage... :unsure:
/ pickup truck size #418
I had a '79 that I bought used for only a little more used in '82, pretty much the same truck as yours except mine had the 302/3 in the tree. Decent enough truck though it was geared a little higher than I'd like. Sold it for $1500 in '98, other than some rust in the bed still in good shape.
Not something I drove everyday, and it tended to be hard to start if it sat for more than a week or two.
/ pickup truck size #419
Trucks and cars, that's one thing I miss today.... inline 6's. If all you looked at was peak HP, they might not catch your eye..... if you wanted a long-running work engine (y) .
Chev Stove-bolt 6. My Dad had several, and I still have one.
Rgds, D.
/ pickup truck size #420
Well that is one of the few Ford 300's that had problems. Several Farmers around us including my uncle had them but in 3/4 tons pulling hay wagons and gooseneck stock trailers. I believe my Uncle's was a 79 or 80. It didn't pull heavy wagons or stock trailers quiet as fast or as well as the GM 350's did but it wasn't out ran that much. His upside was when empty he said he was getting 17-18mpg while the 350's only got 12-14. We eventually got a 83 Chevy 3/4, 350, manual and 3.73 gears, It was a stout pulling truck but Dad hated the 13mpg empty or trailering even though I told him that wasn't bad since we lived on a very hilly gravel road and it rarely was on the highway more than 10 miles and we were using it to pull and haul way more than we ever could with the 305/350V8 1/2 tons he was used to. Oh well, what does a teenager know. :)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2020 DRAGON ESP...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2018 Toro Workman HDX Diesel Utility Cart (A59228)
2018 Toro Workman...
Tug Boat with Tri Axle Magic Tilt Boat Trailer (A59231)
Tug Boat with Tri...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
