pickup truck size
/ pickup truck size #261
Well i dont have a pickup truck... their larger frontal profile, diffs and transfercases to add weight and friction (fuel consumption and road tax) make it unattractive in Europe to use as commuter vehicle.
When i follow the line of cars that my father drove to what i drove within the same class, you see a steady climb from a 1200kg 245 to a 1350kg 740 to a 1450kg 850 to a 1470kg S70 to a 1540kg V70 2nd gen, where the 3rd gen weighs 1700kg and its successor the V90 over 1800kg...
Then, looking at tractors: The big field tractors of the 90s were the Case Magnum and Deere 55 series. The Magnum ranged from 155 to 238 engine hp, weighed 9 to 10 ton and used the Cummins C series block. The Deere 55 series was from 128 to 228hp and used the Deere 7.6 liter engine, which was stroked to 8.1 liter and later to 9 liter, nowadays churning out anything between 250 and 400hp.
The 155hp of the 9 ton Magnum 7110 is now found in a 5.5 to 6 ton 4 cylinder tractor...
The Case Magnum engine was stroked to 8.7 liter and now putting out between 240 and 380hp.
Both series had wheelbase and weight increases so they actually moved up a class, yet they are still built on the same basic architecture. Its just that the Magnums Cummins was swapped for an Iveco engine of parent Fiat, and got a CVT transmission dug up from the IH archives, which patented a Vari-Torque transmission in 1981 and built working prototypes.
The Deere also got a CVT option, but also an e23 powershift, which is actually an iteration of the 12 speed powershift and the 24 speed hi/lo gearbox of the 1989 8850 articulated tractor...
On early 8000 series tractors, Deere made room for a conventional cab by moving the engine forward by means of bolting a cast iron spacer between engine and transmission of what was under the skin, a plain old 55 series skid unit with a new cab and electronic shifting...
When looking at European compact cars, we got the Golf (or Rabbit on your side of the pond) in 1974 as a replacement of the Beetle. It grew in size so in the 80s VW introduced the Polo. The current generation Polo is a more mature car than the clean sheet design Golf 3 was in the early 90s. Meanwhile, VW introduced a new compact car, called the Up! to serve the market segment where the Golf was positioned 45 years ago.
Manufacturers allways make a new iteration of a model, bigger, more expensive, and more luxurious, they never introduce a new model line upmarket, they allways lure customers to follow them into the next generation of what people already own.
Though using a pickup truck for commuting is an American thing, upmarketing existing model names through its generations is a universal commercial practice.
/ pickup truck size #262
You are correct! There is another thread about a member who bought a $40,000 tractor, kept it 10 years and put only 200 hours on it! I have no idea how anyone could keep a tractor for 10 years and only put 20 hours a year on it!
Must have skimped on house maintenance to spend that kind of money!
Let's set the record straight... The tractor was 8.5 years old, had 212 hours, and I had exactly $27,000 into it. I sold it for $25,500. Leave it up to you to %^&$ up the facts. So... I got 100 months of use @ the cost of $1500 dollars and less than a thousand dollars worth of diesel fuel and 3 oil changes... Sounds like good business to me.
/ pickup truck size #263
I think it's because the cars are too small today. My dad has a 32 Ford Fordoor that is bigger than my 2014 Extended cab pickup and more luxurious inside. Now that was a car! I'm 6'2" 200 lbs. and the only cars that work for me are the Europeans that have doors that open all the way and better ergonomics. Can't understand what bigger people do if they don't have truck ...
The cab-forward design of modern cars is supposed to be giving us good interior space, but sometimes having a close look at something much older will leave you scratching your head - This is Progress ? (One of the reasons I like watching Leno's garage.....).
In recent years, a buddy of mine restored a 1971 Ford Maverick that had been parked a very long time. Guys your size and bigger that sat in the restored vehicle exclaimed about the amount space in front. OK, as a mid-size 2 door, the back seat was best suited to kids, but still, in the late 60's when that was designed, they really got the space in front well sorted.
Rgds, D.
/ pickup truck size #264
That's right, you and I live in two different worlds.
I had an appointment with my eye doctor last week which meant a round of 350 miles (~ 563 kilometers). That's because there are no eye doctors anywhere closer to me, nor a Home Depot where I can buy building supplies, etc. Between my place and Reno, the nearest "city" 175 miles away where the doctors live and the shopping is, are but 3 tiny towns where all you can buy is fuel and a snack. So - when I have to make a "town" run my truck comes back fully loaded...sometimes I even take a trailer to haul everything.
So - I have no use for a car. I need something that can haul a lot of "stuff". This is my world:
/ pickup truck size #265
I am happy with this truck, maybe looking for one of these special trucks might be the answer,,
The dealer really priced this truck right,, for me,,
I am still amazed at the low price I ended up paying for the Alaskan,,
I'm not in the market at the moment, but I could see myself attracted to a well thought out work-targeted package like that....... all the while still grumbling about too many bells/whistles :cool: Ha.
In the olden-days, you could find some gems on GM's option-list for cars..... while a rear-widow defroster might have been hundreds of dollars, you could upgrade to a heavy-duty suspension for something like $18.
They might be getting like hen's teeth in the market, but it's good to hear that there are still some intelligently spec'd work packages available....
Rgds, D.
/ pickup truck size #266
Top Gear had an episode of Clarkson trying to drive an F150 to the "shops" in the country town near his home. Didn't fit anywhere.....
Lots of open space in N. America, and generally much bigger roads than much of Europe. Not that I'd want to park a 1 ton crew-cab 8' box p/u in NYC, San Francisco, or Vancouver.....
I was watching a motorcycle-trip video shot in Finland - roads were well paved, but it was startling to see a motorcycle meet an oncoming car; the roads were extremely narrow by our norms.
DE had a good example of using a truck's capacity for personal use, but much of the time, personal pickup trucks ride around here virtually empty...... and our fuel prices are significantly higher than most of the USA has. Work and Farm p/u trucks account for a bit of the market, but the majority are owned by Townies that want them mostly for size/comfort/status reasons.
The recent 10-speed p/u transmissions do help make the modern p/u fuel bill a bit less painful....
I've only made one trip to Europe. I was surprised to see a few US pickup models on the road near Stockholm, and there was one brand new full size Tahoe parked at a nice residence near the hotel I was staying at, but I'd expect those are priced in the local market similar to driving a high-end Mercedes car/SUV here. Not for avg folks, like me.
Rgds, D.
/ pickup truck size #267
That pic reminds me of Rte 50 through Nevada and Utah ..." The Loneliest Hwy " in the world...
/ pickup truck size #268
Yup. 152 miles between Ely, Nevada and Delta, Utah...and there is literally NOTHING between the two towns but desert and mountains. Photo taken in Utah but the mountains in the distance are in Nevada.
/ pickup truck size #270
I’m not questioning anything about what you paid/sold.
I was commenting about the lack of use/low hours.
/ pickup truck size #271
All right, but on a full tank of 70 liters of diesel, i can drive 1300km or 800 miles.. or 500 miles when i tow a 3 ton trailer. I have no use for a pickup truck, i can haul clean goods in the boot or dirty (and/or heavy) goods on the trailer.
About 5% of my mileage is with a trailer, i dont want to haul a bed along when i dont need one.
/ pickup truck size #272
I don't know if it differs in Holland or not, but here in Portugal, other than the extra fuel consumption, which is not that much more, it's very attractive to own a pick up truck. Those are registered as goods vehicles and pay like €53 on the yearly road tax, very anywhere from €150 to €250 on the common car or SUV, depending on the displacement and emissions output.
/ pickup truck size #273
Amazing picture. Beautiful
/ pickup truck size #274
Aside from heavy towing, many commercial users here will opt for full-size vans - high volume of secure storage that is well suited for shelving, workbenches etc.
We have some crazy-tall high roof (factory production, not customized) vans available here now...... tall enough that I wouldn't want to drive one empty through a bad Winter storm !
I see a lot of 4x4 Mercedes Sprinter vans here lately - nice for Winter, and job site visits. GM used to have a full-size 4x4 van option, but I'm not sure if that's still in production.....
Rgds, D.
/ pickup truck size #275
They changed that rule, now vans and pickuos are taxed as passenger cars, but you can deduct that if you have a VAT number: meaning that a VW Caddy is no longer attractive as a commuter vehicle... let alone a heavy pickup truck.
A former colleague of mine, who started his own heavy equipment repair shop, is fond of US pickup trucks and bought a 2nd gen Ram Cummins to drive in the weekends. For work, he puts his tools in a Citroën Berlingo...
The Dodge he has on commercial license plate, he got a commercial drivers license for it, in order to avoid tax on heavy passenger vehicles.
/ pickup truck size #276
Rgds, D.
Yes, America is slowly adopting European vans, now they become available with decent power and a lean Diesel.
In the early 80s when Mercedes had just taken over the vans of Hanomag-Henschel, they came with a 50hp diesel in it. 20 years ago during my apprenticeship we had a big Sprinter (tall and long roof version) whose base engine was a 70hp diesel... it was useless on the highway, weaving into a traffic lane on the on-ramp was often dangerous. Those were a far cry from the current 319 Sprinter with 190hp and, most important, bags of torque...
Yes, high and tall roof options are a challenge in strong crosswinds: but you guys get the 2500 and 3500, not even a 1500 (Sprinter 200 in Europe) those are spooky in long and tall execution...
Merc has a great ESP which counters crosswind jolts pretty good, which makes driving in strong crosswinds absolutely safer..
/ pickup truck size #277
This video is about Ram but it tells the story as to why full size pickups are so popular.
/ pickup truck size #278
I found wind-up windows......
HiLo, and Mech dff lock :cool:
Too bad I'd have to move to the UK, and grey-market it in......
I miss the Suzuki's here..... very popular, and some still live on in BC (less salt on roads), scrambling along goat-paths.....
Rgds, D.
/ pickup truck size #279
The price of fuel will downsize vehicles unless you're a millionaire.
