Picking a first tractor
   / Picking a first tractor #41
Did you mean location of the moment of inertia? Or that the centre of gravity of an object may change due to a change in physical orientation.
   / Picking a first tractor #42
Yes, now we are getting somewhere. I meant both. We can consider the rotational inertia to be one of the forcing functions in a complex set of forces that affect stability, and center of gravity is a handy way to look at the vertical forces by themselves when everything is static - which it rarely is.
In the OSH attachment, you can see that when the mowing attachment is rotated from one side of the tractor to the other, the total weight did not change but the center of gravity did change. It proves a point.
Unfortunately, I don't think that OSH document goes into enough detail to be of much help. But tractor stability is a complicated subject. If it were easy, the tractor manufacturers would have solved it long ago.
I think this would be a good place to leave the physics and get back to moving dirt & choosing tractors.
rScotty
   / Picking a first tractor #43
Centre of gravity can change but as shown on the diagrams weight has no effect on it’s placement which is what was originally said.
Nice physics detour:) I am actively looking for a gently used L2501. I plan to bring a friend who owns couple tractors with me, but Is there a checklist somewhere that shows me what to look for pre-purchase? Thanks again.
   / Picking a first tractor #46
Thanks for sharing this document.
   / Picking a first tractor #48
I guess you can probably take a few minutes to create a checklist on what to look for, listed are a few of the things I would look for:
1) Leaking cylinders
2) Leaking fluids from under tractor
3) Check for slope on pivot points, lack of grease
4) Condition of tires, cuts, worn etc.
5) Cleanliness of radiator
6) Overall appearance goes to how unit was cared for
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
