Pick Up Truck Headache Rack
   / Pick Up Truck Headache Rack #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I have been toying with the idea of building my own headache rack that would match my front grill guard. I looked at several ones for sale on the internet and decided to use 2" square tube for the main framework.
I laid out the basic shape on a piece of plywood to use as a pattern/weld jig.
For a cleaner and more professional appearance I welded caps on the end of the tubes that would not get covered.
Then I used a 4 1/2" disc grinder with a sanding flap wheel to smooth over the welds.
I then used 1 x 1 angle iron for the horizontal louvers. I cut blocks of wood to use as spacers so they would be evenly spaced.
I just tacked thenm all in place before welding them solid to make sure everything looked straight.
My truck has a kind of western theme so I added some horse shoes for good luck.
(insert your own red-neck joke here)
After welding everything up solid I ground all of the butt welds flush and then went over them with the sanding disc to get out any grinder marks.
Then I welded on the 2 pieces of 2" angle that would attach to the bed and hold the rack vertically in place.
I wanted to be able to install the tool box for my truck with out drilling holes in the top rail. So I welded 2 tabs on to the 2" angle iron that I could blot my tool box to.
Up here in MI we have alot of rain, snow, and road salt so protecting the steel from rust is a big concern. So for the primer coat I used POR-15.
By the way once it dries on your hands it will have to wear off!! 3 days later and I still have gray blotches on me. /forums/images/graemlins/smirk.gif
Now for 3 coats of gloss black paint.
I wanted ot mount the rack with out drilling any holes in my truck bed. So I design a method of 4 clamps that use 1/2" bolts to clamp the rack to the bed rail.
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
