Pick Up Truck Headache Rack
   / Pick Up Truck Headache Rack #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I have been toying with the idea of building my own headache rack that would match my front grill guard. I looked at several ones for sale on the internet and decided to use 2" square tube for the main framework.
I laid out the basic shape on a piece of plywood to use as a pattern/weld jig.
For a cleaner and more professional appearance I welded caps on the end of the tubes that would not get covered.
Then I used a 4 1/2" disc grinder with a sanding flap wheel to smooth over the welds.
I then used 1 x 1 angle iron for the horizontal louvers. I cut blocks of wood to use as spacers so they would be evenly spaced.
I just tacked thenm all in place before welding them solid to make sure everything looked straight.
My truck has a kind of western theme so I added some horse shoes for good luck.
(insert your own red-neck joke here)
After welding everything up solid I ground all of the butt welds flush and then went over them with the sanding disc to get out any grinder marks.
Then I welded on the 2 pieces of 2" angle that would attach to the bed and hold the rack vertically in place.
I wanted to be able to install the tool box for my truck with out drilling holes in the top rail. So I welded 2 tabs on to the 2" angle iron that I could blot my tool box to.
Up here in MI we have alot of rain, snow, and road salt so protecting the steel from rust is a big concern. So for the primer coat I used POR-15.
By the way once it dries on your hands it will have to wear off!! 3 days later and I still have gray blotches on me. /forums/images/graemlins/smirk.gif
Now for 3 coats of gloss black paint.
I wanted ot mount the rack with out drilling any holes in my truck bed. So I design a method of 4 clamps that use 1/2" bolts to clamp the rack to the bed rail.
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
5-500 3 pt Spreader (A50515)
5-500 3 pt...
(INOP) OTTAWA S/A SPOTTER TRUCK (A51243)
(INOP) OTTAWA S/A...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
