Pick Up Truck Headache Rack
   / Pick Up Truck Headache Rack #1
GeneD14
Tennessee
Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
I have been toying with the idea of building my own headache rack that would match my front grill guard. I looked at several ones for sale on the internet and decided to use 2" square tube for the main framework.
I laid out the basic shape on a piece of plywood to use as a pattern/weld jig.
For a cleaner and more professional appearance I welded caps on the end of the tubes that would not get covered.
Then I used a 4 1/2" disc grinder with a sanding flap wheel to smooth over the welds.
I then used 1 x 1 angle iron for the horizontal louvers. I cut blocks of wood to use as spacers so they would be evenly spaced.
I just tacked thenm all in place before welding them solid to make sure everything looked straight.
My truck has a kind of western theme so I added some horse shoes for good luck.
(insert your own red-neck joke here)
After welding everything up solid I ground all of the butt welds flush and then went over them with the sanding disc to get out any grinder marks.
Then I welded on the 2 pieces of 2" angle that would attach to the bed and hold the rack vertically in place.
I wanted to be able to install the tool box for my truck with out drilling holes in the top rail. So I welded 2 tabs on to the 2" angle iron that I could blot my tool box to.
Up here in MI we have alot of rain, snow, and road salt so protecting the steel from rust is a big concern. So for the primer coat I used POR-15.
By the way once it dries on your hands it will have to wear off!! 3 days later and I still have gray blotches on me. /forums/images/graemlins/smirk.gif
Now for 3 coats of gloss black paint.
I wanted ot mount the rack with out drilling any holes in my truck bed. So I design a method of 4 clamps that use 1/2" bolts to clamp the rack to the bed rail.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
