PHD Operation
/ PHD Operation #1
SevenCorners
Charlottesville VA
Jinma 224 2004
I have an old PHD I bought used out of the local trader newspaper for $150. It works fine and came with an 8" auger. My question is how should I properly operate it? I do not have an operators man. I will be replacing and building this spring probably 1/2 mile fence line with a post every 8'. What is the proper/correct way to use the 2 stage clutch/gears/shuttle FWD REV/FEL/3PT Raise Lower? We have pretty rocky soil and there is no level land.
/ PHD Operation #2
The basic steps for operating a PHD are the following:
0) Before you dig, put a piece of colored tape on the auger to mark the depth you want to dig. This will let you check the depth from your tractor seat (don't forget that when you dig you'll pile up some extra dirt around the edges of the hole, making it seem like you've hit your tape before your hole is deep enough)
1) With the PTO disengaged, center the tip of the auger over the center mark of the hole you want to dig
2) Lower the auger until the tip presses into the ground right through the center mark for the hole
3) Ease the tractor forward about 3-4 inches, making sure the auger tip stays put in the center mark of the hole (you want the auger to lean slightly at first so that it will straighten up as it goes deeper into the hole)
4) With the tractor at idle or just above, engage the PTO gently and lower the lift arms on your three point hitch
5) About half way down, you may want to lift the auger (not completely out of the hole) to spin off some of the dirt, then lower it again to keep digging
If you're digging in rocky soil, make sure you have a handful of extra shear bolts handy -- you'll likely need them. I'd also keep a pick and/or shovel if your rocks are big. Small rocks are no problem. Bigger ones (volleyball size and bigger) usually have to come out by hand once you hit them.
Good luck.
Parker
/ PHD Operation #3
The only other bit I would add is to remove a square of grass (if it's grassy) where you are putting the hole. It comes in handy to replace it around the base of the post when you are finished ramming back the earth and the roots don't get caught up in the auger. The theory is to replace more soil then you take out after ramming.
I find it better to invest a bit of time to get the PHD lined up correctly to drill a straight hole because it's a PITA to sort it out after. I have found a sissor action soil removal shovel invaluable to remove the soil from the hole esspecially if the soil is dry.
That's good advice to stay on the tractor. Also what size posts are you using? You will want to match the post to the auger, no use drilling an 8" hole for a 4" post with a 6" will do.
/ PHD Operation #4
I've found it easier to "start" the hole with a shovel. Just make a hole 6" deep for the auger. My property has tons of rock and a small rock really throws off the auger when it hasn't begun to dig in yet. The starter hole helps eliminate this ... just my 2 cents ... Scozz
2025 Hydraulic Tire Lifter Skid Steer Attachment (A66734)
2025 Hydraulic...
2018 JOHN DEERE 524K-II WHEEL LOADER (A65056)
2018 JOHN DEERE...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
7ft Fork Extensions (A66734)
7ft Fork...
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
