Dirt Moving PHD on front
/ PHD on front
Tom H.
Thanks for the reply, the specs on my B26 is 11.2 gpm and I have come up with a way to mount it to the middle of my bucket and if that does not work I have have a quick connect bucket so I can remove the bucket if I have to. so I need to figure out what hyd. motor I will need and get the part number for the remote to put on the tractor. thanks again
/ PHD on front #12
The local Kubota Dealer said he had set up b26's with a backhoe mounted Hydraulic Post Hole Digger for a local landscape company...
Made it easier to reach hard to get to places and the thumb hydraulics were used to power the auger.
/ PHD on front
had not thought of that, that is why I like this site. great idea got me to thinking now. yea I know I'm going to have a headache
/ PHD on front #14
/ PHD on front #15
Ultrarunner
Good point about the PHD on the hoe. A hydraulic PHD mounted in the middle does not let you see the tip when setting it down. I still think 11 gpm is marginal to run a hydraulic PHD. What is the hydraulic psi of a B26?
/ PHD on front #17
/ PHD on front
Radman1, the psi is 2250 to 2400. I like the idea of putting it on the backhoe since that would save dollars and I would not have to add a new valve.
bad boy zero turn 72 (A56859)
bad boy zero turn...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2007 Range Rover Sport AWD SUV (A59231)
2007 Range Rover...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
