PHD on 790
   / PHD on 790 #1
edgaines
South Carolina
JD790
I got a PHD for the 790, then found that the 3PH wouldn't go high enough to get it off the ground. I ordered another adjustable link to replace the fixed "down link" on the left side of the 3PH, to get it higher. I realize I will have to drill the hole, then, with the auger down, adjust out the links to get to the right depth. Anyone else have this situation?? /forums/images/graemlins/tongue.gif
   / PHD on 790 #2
Does the yoke not have any adjustment holes in it?
   / PHD on 790
It only has 1 "extra" hole in it, and it raises only about 1".
The price of the adjustable is $179, but I gues I gonna have to bite the bullet anyhow.
   / PHD on 790 #4
Can you add plates like in this picture?
   / PHD on 790 #5
Ed,
Do you have an extra long auger bit? I have a PHD and it is probably 6 to 8 inches off the ground when raised all the way up?
   / PHD on 790
I got it fixed, and working by drilling holes in the down link forks from the lift arms 1.5 inches up from original. Works great now.
Thanks for all the suggestions.
   / PHD on 790 #7
Are you sure your drive arm isn't just too long? Mine was and I had to cut it. I have a 790 and greenline PHD.
Buck
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
Scag 36 Advantage Push Mower (A50121)
Scag 36 Advantage...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
