PHD lost torque
/ PHD lost torque #1
augerin
Marbury
Scat trak
My post hole digger, running on an old skidsteer (18gpm) doesn't seem to have any torque. The PHD drive is a roller stator motor. Took the qd's out, but now wondering how to check flow on the aux circuit. Fluid level is full, all other functions (lift and curl) work ok.
/ PHD lost torque #2
You can bung up the return line and see if the pump deadheads. You can also put the return line in a bucket and measure the flow (and reuse the oil). That's if you don't have a pressure gauge to put in the system right in front of the motor ...
/ PHD lost torque #3
Does the PHD spin at the proper speed under no load or minimal load? If yes then you receiving full flow to the motor.
Does the motor on the PHD get hot rather quickly when under load? If yes this would point towards the motor leaking or bypassing flow internally.
Does it sound like the hydraulics are building pressure ? I.e. Similar sound to curling the bucket full stop and hold it there briefly.
/ PHD lost torque
I don't have a bucket that big :eek: Pressure isn't same as flow, is there a formula to convert?
/ PHD lost torque
Looks close, but don't have a tach to measure it with.
Haven't checked, what is quick? 3-5 minutes How hot is too hot?
Not with PHD, but definitely with grapple digging roots/stumps.
I've got new filters on the way, but leaning towards bypass on the motor. With no load, PHD spins in both directions. Under load, it starts to drill then stalls like it's hitting a root or rock. When I check the hole, nothing to be found :shrug:
/ PHD lost torque #6
In 3 - 5 minutes with the motor stalled you should be able to feel a definite temperature difference from inlet line to the outlet line if the motor is bypassing.
Does the grapple run off the same connections as the PHD? If yes this points towards a problem with the PHD
Responses are inside the quoted lines
/ PHD lost torque
I'll check the lines for temp change. Grapple and PHD do share the same ports. Grapple open/close time appeared to be slow. Never thought about getting a reference for it either though. That's why I'm waiting on a new set of filters, thinking flow is restricted somehow. Maybe dumb on my part, but they are due anyway. Of course, not getting the wife's fence done is quickly becoming my priority problem.
/ PHD lost torque #8
When it stalls can you hear the pressure relief valve open?
Is it hex drive to the auger or shear bolt?
Use a big pipe wrench and see if you can turn it without the skid steer running.
/ PHD lost torque
You had better get this solved NOW:D
It was more complicated than expected. My buddy had been using the PHD for an extended period of time. What I did not notice was the motor was a different one, how the heck did that happen? He had an issue with his conveyor and borrowed the PHD motor. He put the wrong one back on the PHD. Instead of 1900 ft. lbs of torque on the auger, I was getting 750. It would dig ok in dirt/clay but dry clay was a nogo.
Fence is up, horse is free and wife is momentarily appeased.
/ PHD lost torque #11
Glad to know you have the problem resolved and your wife is momentarily pleased.
/ PHD lost torque #12
I am kind of wondering just how good a "buddy" he is. How could you mix up the two motors? I am also kind of surprised that the two motors were direct replacements for each other. But I suppose if the two motors were the same size and shape he may not of realized the difference in torque.
Doug in SW IA
/ PHD lost torque
Doug in SW IA
They were both black :D He's a farmer and doesn't worry about specs. If you can make it fit and work, it's :thumbsup:. He keeps baling wire, twine, duct tape, hammer and 2 screwdrivers on all of his tractors and trucks for emergency repairs.
He is a great guy and very good friend, would give me anything he has if I ask or he thinks I really need. He has cut and baled for me (free, wouldn't even take fuel money), run errands, help with fence, babysit animals, will answer the phone at 2 am, etc.etc. He's just not much of a handyman, that's what I normally do to help him.
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
CATERPILLAR ROLLER (A65053)
CATERPILLAR ROLLER...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
AGroTK SDA84 (A64127)
