PHD for 2210
/ PHD for 2210 #1
DJLX
East TN
JD 2210
Since I'm in a posting mood I thought I would get your opinions on post hole digger. I will be putting in a new deck behind our house this fall and will need to put in the concrete footers. I'll probably buy those tubes and stick down 24" or whatever the frost line is. This will be in TN clay and don't want to do it with a manual digger. Probably no more than 10 holes total. I realise I could rent a gas power 1 or 2 man phd but thought a 3 pt would be better (means less work). Does anyone have a recommendation for the 2210?
/ PHD for 2210 #2
DJLX,
deere_x475guy has the Speco unit on his 2210 and seems to be really happy with it. /forums/images/graemlins/tongue.gif
/ PHD for 2210 #3
I don't know anything about post hole diggers, but I am in awe of your decision to buy an expensive new toy...err, implement for which you have only two hours of work projected.
You set a high mark for the rest of us to aspire to. I salute you sir!
/ PHD for 2210 #4
My tractor supply Speco PHD works great on my 2210. With the digger all the way up your 6"-7" above the ground. Just did 84 holes for a new horse paddock.
/ PHD for 2210
Argonne-LOL.
Yes it will be only a couple of hours, if that with the tractor but might take days with a shovel. I put in some steps up the slope for our pool and had to use a pick axe to break up the clay. This was before I had a 2210 otherwise I might have made 49" wide steps. /forums/images/graemlins/smirk.gif
/ PHD for 2210
LOBO 56
You in the Freehold area of NJ where all the horses are? We have some friends there that have horses and have overseen some shows at the Horse Park. They did that thing, driving I think it's called, where you have a carriage that is decorated like a tailor or other craft and is judged. Please excuse my ignorance on this subject. Back to tractors...
What size is your auger and have you had any problems with PHD operation?
/ PHD for 2210 #7
Live 2 miles from the horse park on the same road. I have the 9" auger. For $485.00 it's the best auger on the market that fits a 2210. You can buy other brands and the price jumps $300 - $400, but for someone that don't dig holes every day it's great. I've probably dug 450 - 500 holes with out problem.
/ PHD for 2210 #8
DJLX,
I’ve used my father-in-laws Woods PHD to punch a bunch of holes in our Indiana clay for a fence and play ground equipment at our church. It’s a heavier version and has a 12 inch auger. Worked just fine, just have to make sure you don’t burry it too far or you may not be able to extract it from the hole. I did hit some buried trash (an old steel barrel) and had to use a large pipe wrench to screw it back out of the ground.
Overall it worked great. My 2210 had plenty of PTO power, just a little weak on rear hydraulics for extracting. I had punched 23 fence holes and ~30 play ground equipment holes to a depth of 24” with little issues. I’ve been surprised at how useful my in-law’s PHD has been. I’ve used it more than he has.
Good luck,
John
/ PHD for 2210 #9
I've got the Speeco PHD from TSC for my 2210. It works just fine. I've never had a problem with it. I have the 9" auger. I was thinking about getting the 12" auger to do the footers for the deck too.
/ PHD for 2210
cadblaster- I plan on using 4x4 post and think that the 8"sonotubes would work. Any reason I should go larger to 10 or 12"? I'll probably go about 24-30" deep.
/ PHD for 2210 #11
I've got the Greenline EM5500 PHD for my 4600. Although the 4600 is bigger than the 2210, the Greenline (it's actually yellow, but I'm going to paint it green this fall) can use different size augers and I got the 12" unit for my perimeter fencing. I'm digging over 150 holes for the fence (3/4's done now) and other than a few shear pins (**** rocks), we've gone through most everything with it and not had any problems. I usually have the tractor running at idle when I'm digging as there is plenty of power to handle things. One thing I've noticed though about using the 3-pt PHD is that you need to sometimes dig a little starter hole to get things going as the grass will bind a bit, but other than that it goes fine.
The Greenline is a bit more than the Speeco, but since the warranty is honored through my Deere dealer I figured an extra $100 was worth it. We just don't have enough TSC's up here in MN....
-Bob
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
John Deere 450 (A64119)
John Deere 450...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
FORD 8340 POWERSTAR SL TRACTOR (A64280)
FORD 8340...
2022 EZ-GO ELITE...
