PEX for shop air lines?
   / PEX for shop air lines? #41
The first shop I ever worked in had 3/4" copper for air distribution. 175 psi, 10 hp 3 phase compressor (Art Arfon's old shop!) Never an issue, but my shop is getting black pipe.
   / PEX for shop air lines? #42
No matter what U use be sure you create a drop below your female and install a ball valve to bleed the moisture.
   / PEX for shop air lines? #43
I believe it's rapidair that has those on every drop.
   / PEX for shop air lines? #46
   / PEX for shop air lines? #47
some one smarter then I might have a more accurate answer. But here is my take on it
the air in my shop and the air outside my shop both have the humidity level... so no matter where I pull my compressor intake to... the condensation will be the same.
thoughts?
   / PEX for shop air lines? #48
thoughts?
I should have been more specific. As in pulling 20F degree outside air into a 60F degree shop and compressing it.
That’s something I’d also be interested in hearing more about too.
2021 BOBCAT T595 SKID STEER (A52706)
2021 BOBCAT T595...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55758)
Toro GreensMaster...
