PEX for shop air lines?
/ PEX for shop air lines? #41
The first shop I ever worked in had 3/4" copper for air distribution. 175 psi, 10 hp 3 phase compressor (Art Arfon's old shop!) Never an issue, but my shop is getting black pipe.
/ PEX for shop air lines? #43
No matter what U use be sure you create a drop below your female and install a ball valve to bleed the moisture.
I believe it's rapidair that has those on every drop.
/ PEX for shop air lines? #46
/ PEX for shop air lines? #47
some one smarter then I might have a more accurate answer. But here is my take on it
the air in my shop and the air outside my shop both have the humidity level... so no matter where I pull my compressor intake to... the condensation will be the same.
thoughts?
/ PEX for shop air lines? #48
thoughts?
I should have been more specific. As in pulling 20F degree outside air into a 60F degree shop and compressing it.
That’s something I’d also be interested in hearing more about too.
/ PEX for shop air lines? #51
/ PEX for shop air lines? #53
So what is the reason for intaking outside air?
The intake noise can be quite loud on air compressors, so piping the intake to draw outside air should reduce sound inside the building.
/ PEX for shop air lines? #54
Won't it cause more condensation to pressurize outside air?
It depends if the shop is heated in the winter and/or AC in the summer. Take air from outside, while the shop is heated, makes it drier in the winter. Opposite is true in the summer if the shop is AC. If it is not AC and is hotter inside than outside the outside air would be possibly also drier. Amount of water in the air is a function of the temperature.
/ PEX for shop air lines? #55
as mentioned... a large portion of the noise a compressor makes comes from the air intake, so I hope to reduce the noise level. And the closet my compressor is in is almost air tight, so drawing air form outside the closet will be better for the compressor
/ PEX for shop air lines? #56
If you plan on doing ANY sandblasting you really need to address the moisture problem at the compressor level. I have a 7.5 hp compressor and the water was ridiculous until I found an air to fluid heat exchanger that would cool the charge so the water would drop out at the tank, not in the lines.
I use Wirsbo for plumbing projects and I can tell you stuff in indestructible.
/ PEX for shop air lines? #57
Good stuff guys. Thanks for the education!!!
/ PEX for shop air lines? #58
When sandblasting, I would get water coming out of the line. I made a Franzinator and was amazed at how much water it removed.
Ken
/ PEX for shop air lines? #59
Forgot to mention, there is an airline rated PEX. As far as I can tell, it is the same stuff that has just been tested and certified for airline use but maybe there is something special about it.
Ken
/ PEX for shop air lines? #60
Yup. Plumbed my entire garage air system with PEX tubing. Works great, easy to work with, inexpensive, safe, non corrosive...what more could you ask for?
2019 CATERPILLAR 239D SKID STEER (A65053)
2019 CATERPILLAR...
2011 Ford F-550 4x4 Altec AT37G 37ft. Bucket Truck (A64556)
2011 Ford F-550...
Location Info Please
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
Spirit Bike (A64557)
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
