Petrogen torches???
   / Petrogen torches??? #2
They only mention cutting...no welding. If cutting was all I was interested in, propane might be a better way to go.
You didn't hurt yourself by going with acetylene. The only real limitation acetylene has is the rate of emptying the bottle...not supposed to use more than 1/7th of the bottle capacity per hour. Rosebud tips can get you into that territory.
   / Petrogen torches??? #3
I looked at oxy/gasoline at one point. Didn't like the idea. Gasoline spills are harder to deal with than propane leaks.
I stick to propane for cutting & heating and acetylene for welding. (when I'm not using electricity for welding that is...) Never have to worry about how fast I'm draining the tank that way. As long as you make sure your hoses are rated for both, you can even get away with just swapping the tip & the tank to go between cutting and welding.
   / Petrogen torches??? #4
Do please enlighten me. I am most interested in cutting, bending, etc.
Is this Oxy-propane you're talking about? I had thought that propane wouldn't get hot enough for any of this, but I have only really use straight propane, nothing else.
   / Petrogen torches??? #5
Propane doesn't do much for welding, but if you want to cut & heat, tips are available for your regular O/A torches. You'll use more oxygen when cutting with propane.
As long as your hoses are rated for propane you can put your acetylene regulator on a propane tank, change to a propane tip & enjoy...
   / Petrogen torches??? #6
Oxy acetylene gets to 6300F or so. Oxy Propane gets up to 5300F or so and steel melts at 2750, so oxy propane is plenty hot to cut with. Propane is exceptionally good for heating because it's less expensive and you don't have to worry about the 1/7th rule that applies to acetylene.
I think all you need to use propane on your oxy acetylene rig is a different tips and maybe a different fuel regulator. I know the acetylene regulator would not fit a propane tank and I think a propane tank has much higher pressure.
   / Petrogen torches??? #7
Actually...
An acetylene regulator is a perfect fit on a standard propane tank. I use a 2-stage acetylene regulator for my setup.
   / Petrogen torches??? #8
I bought a set of small victor torches about 4 years ago and have been using them exclusively with OXY/Propane. All good so far.
A 20 lb tank of propane will last me thru about 6-8 tanks of OXY when cutting scrap.
   / Petrogen torches??? #9
Darryl,
I spent some time researching the gasoline setup and really liked what I read but I did not buy the unit and do not know of anyone that has had experience with the setup. If what is said about it on the Internet is true and it will meet your needs I would go for it. Let us know if you do. It is a real pain running out of fuel on a weekend and trying to find a supplier that is open is near impossible. Lots of gas stations are open 24 hours.
   / Petrogen torches??? #10
I'm glad to finally find another human being on the planet that knows what a Rosebud heating tip is. Around here people think your're talking about a flower. One of my co-worker was talkiing about getting a full set of wrenchs, yep clear up to 3/4". He said he didn't know what he would do with such big wrench's though. bjr
   / Petrogen torches??? #11
Kernopelli said:
Anybody have or know anything about these? I would be very interested in hearing if they are as good as they claim. I just got a new oxy/acetylene set up and wish I had seen this first.
I had information on these things sent to me a while back. I though it looked like a great idea and wanted to buy one on the spot, until I got the information and saw the price. A base rig is ~$1100. Compare that to a $200-300 Oxy/Acy rig, and that was the end of that. I suppose if you used it all the time the gas rig would probably pay for itself after a while, but for my occasional use, too much dough.
JayC
JayC
I hadn't checked on price. Sheesh! I thought the $$$ for my oxy/acy was hard to part with. I'll be sticking with what I've got, thank you!
   / Petrogen torches??? #13
Kernopelli said:
Anybody have or know anything about these? I would be very interested in hearing if they are as good as they claim. I just got a new oxy/acetylene set up and wish I had seen this first. Petrogen | Petrogen Oxy-Gasoline Cutting Systems Home Page
Darryl
I also looked into this unit a year ago. Just type the word petrogen in the search window, and it will take you to the site. This unit is used mostly for rescue and demolition. It is very cheap to use, and it will cut larger steel, stacks of steel, and will probably cut a car up in short order. Gasoline will give you an extremely hot cut. After your initial investment, you would save on cutting gases in the long run. By the time you purchase a regular cutting and welding set, plus the tanks, you are looking at $350 to $500.
I think the basic petrogen set is around $1100. I had also asked the company about a straight torch for CNC metal cutting, although you could adapt the 90 degree torch to work. Solenoid control would be used to switch the oxygen and gasoline on and off. With this setup, you should be able to cut some serious steel with precision.
   / Petrogen torches??? #14
We want to have one gasoline cutting torch for our scrap metal yard. we found another manufacturer of this products and it cost me much less dollars, about 1/3 price of petrogen. it is GYJD gasoline cutting torch
   / Petrogen torches??? #15
We want to have one gasoline cutting torch for our scrap metal yard. we found another manufacturer of this products and it cost me much less dollars, about 1/3 price of petrogen. it is GYJD gasoline cutting torch[/QUOTE]
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
19008 (A56859)
19008 (A56859)
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2017 HAMM H5i P PADFOOT ROLLER (A60429)
2017 HAMM H5i P...
