Persistent oil leak and not running
   / Persistent oil leak and not running #1
RStifle
Massey Ferguson 135
Hello everyone I own a Massy 135 with a three cylinder Perkins diesel. I recently replaced the forward crank seal as It had a pretty bad oil leak. Everything went as expected but when I buttoned it all up it started leaking in the same place and now it won’t start. It ran perfectly fine before the repair. It has sat idle for about two to three weeks.
question: is it common for Perkins 3 cylinder diesels to leak around the timing gear cover? Lastly, what would cause it not to run? It turns over but doesn’t fire off. It has fuel pressure!
Any help will be greatly appreciated!!!
   / Persistent oil leak and not running #2
Do you have a low lever oil sensor? The leak is it just from the cover? Did you use a high temp gasket maker like permatex and follow the directions? I am only guessing as I never had a perkins. I always use permatex instead of a gasket it is handier than have to order or run to town to get one.
willy
No I didn’t. I used the gasket that was supposed to be for my engine. I saw no sensor under or around the cover.
I bleed the fuel system all the way to the fuel pump. It has fuel but doesn’t start. I can’t figure it out!
I'm wondering if the oil leak (as small as it is) is reducing compression and not allowing combustion. Just a thought!!
   / Persistent oil leak and not running #4
A new gasket? Did you tork is to specs?
Make sure in neutral remove jectors and see if you get
fuel and check compression . That's all I can tell you
as I am not a diesel mech. Sorry not much help.
willy
Thanks anyway!
   / Persistent oil leak and not running #6
Did you by chance remove any of the gears when you did the gasket?
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2018 Yamaha 48 Volt Drive 2 Golf Cart (A52377)
2018 Yamaha 48...
2009 John Deere 1050J Crawler Tractor Dozer (A52377)
2009 John Deere...
UNUSED TELESCOPIC LADDER - 2.5M+2.5M (A54757)
UNUSED TELESCOPIC...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
