Persistent oil leak and not running
   / Persistent oil leak and not running #1
RStifle
Massey Ferguson 135
Hello everyone I own a Massy 135 with a three cylinder Perkins diesel. I recently replaced the forward crank seal as It had a pretty bad oil leak. Everything went as expected but when I buttoned it all up it started leaking in the same place and now it won’t start. It ran perfectly fine before the repair. It has sat idle for about two to three weeks.
question: is it common for Perkins 3 cylinder diesels to leak around the timing gear cover? Lastly, what would cause it not to run? It turns over but doesn’t fire off. It has fuel pressure!
Any help will be greatly appreciated!!!
   / Persistent oil leak and not running #2
Do you have a low lever oil sensor? The leak is it just from the cover? Did you use a high temp gasket maker like permatex and follow the directions? I am only guessing as I never had a perkins. I always use permatex instead of a gasket it is handier than have to order or run to town to get one.
willy
No I didn’t. I used the gasket that was supposed to be for my engine. I saw no sensor under or around the cover.
I bleed the fuel system all the way to the fuel pump. It has fuel but doesn’t start. I can’t figure it out!
I'm wondering if the oil leak (as small as it is) is reducing compression and not allowing combustion. Just a thought!!
   / Persistent oil leak and not running #4
A new gasket? Did you tork is to specs?
Make sure in neutral remove jectors and see if you get
fuel and check compression . That's all I can tell you
as I am not a diesel mech. Sorry not much help.
willy
Thanks anyway!
   / Persistent oil leak and not running #6
Did you by chance remove any of the gears when you did the gasket?
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2019 Chevrolet Tahoe SSV 4WD SUV (A55758)
2019 Chevrolet...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
