Perplexing Hydraulic Problem
/ Perplexing Hydraulic Problem #21
Todd - <font color=blue>To test flow, does it make sense to run the FEL hose into a bucket for a 1/4 minute and compare that to the flow for a 1/4 minute on the power beyond hose</font color=blue>
That's precisely what I'd do, except I'd probably only let it run 5 seconds. If you don't compare the rear to the front, it's hard to get any meaningful data, so that's a good idea. Make sure you don't run the reservoir dry, though.
/ Perplexing Hydraulic Problem #22
I think you have a good plan, Todd. I echo what Mark C says about keeping fluid in the reservoir and keeping it clean may also be a challenge. BTW - Can you take a picture of your power beyond connection? I remember seeing pictures of your tractor and trenches. I don't know what I'd see in the picture, but I feel really funny talking to you about something I've never seen plumbed on your tractor. /w3tcompact/icons/crazy.gif If you can't, don't worry about it. We'll just keep at this 'til we figure something out. /w3tcompact/icons/smile.gif
OK Gentlemen. PG&E (Power Co.) signed off on the underground conduit and sand over job so this weekend I can get my pull lines in and push the dirt back in the trenches. Then final sign off and I've got power to the building site when they actually come in and pull the wires.
So I should be able to start working on further diagnosing the problem the following weekend. I need to start prepping 4 acre's for pasture/corral and for this I need the 3Pt.
/ Perplexing Hydraulic Problem #24
Okay, Todd. The first thing you will need to do is to remove all the plumbing required for your backhoe (power beyond, quick connects, etc) and restore the tractor to stock configuration. If the 3PH still doesn't work, then get ready to pull the seat and remove your hydraulic lift assembly...or put it in the shop and have them do it. I could be wrong, but I don't think you have any relief valves you can check without doing this. You might be able to get to the flow control valve, but I doubt it. ...and by the way, I'd love for you to prove me wrong about this, but I think your problem is internal to the hyd. assy./w3tcompact/icons/crazy.gif
OK all you helpful TBN'ers. I've got the tractor home (Got all my trenching signed off and filled back in) and NH got me the manual pretty quickly. I'm going to start with the basic flow tests Saturday along with a study of the Manual tonight. I'll post prelim data tomorrow to post here and hopefully it's an easy fix.
Todd in Placerville
/ Perplexing Hydraulic Problem #26
What happened???? Inquiring minds wanna know!! /w3tcompact/icons/smile.gif
Well, It turned out to be one of those weekends. Since I'm currently building a house (with a garage bay for the tractor) and my current rental garage is stuffed full of our life's belongings, I am forced to wrench on her outdoors. Couple this with the fact that it was the wife's weekend away with the girls and I had the 3 kid's(4-6&8) and on Saturday we got a hell of a storm that blew in, that left Sunday.
What I was able to do in between kid time, was remove the relief check valve in the part I can't name right now because I'm down in Los Angeles on a biz trip so I don't have my manual, to see if there was debris or where there. It looked OK (and just like the manual said it would like) and I reinstalled it and I still have the problem. I didn't run the flow test for various reasons but my gut is telling me that perhaps I ought to first replace the power beyond hose with a new one (Got a local shop that'll make it in a couple hours) and see if it's that simple. Looking at the schematics in the manual, getting into the tranny to check those relief valves is not minor job and I'm not sure I want to tear it apart and while it's outdoors.
The manual also showed how to test the system for pressure so I may go and see about putting together a pressure guage rig with various fittings so I can test in various points along the hyd. system.
Sooooo, hopefully, this weekend I can get a few more steps under the belt because at some point, I'll have to get it to the shop if I can't figure it out. Do you suppose if I get to this point a Hyd. specialist would be better with my manual or would NH be a better place to go?
Talk to you guy's this weekend.
Todd in Placerville
/ Perplexing Hydraulic Problem #28
<font color=blue>Do you suppose if I get to this point a Hyd. specialist would be better with my manual or would NH be a better place to go? </font color=blue>
I'd go with New Holland. A hydraulic specialist would have to spend the time to learn your system and New Holland should be very familiar with the system and have a ready source of spare parts. ...just my opinion.
OK Gentlemen, With Manual in hand and a nice sunny weekend to tinker, here's what we've got.
The easiest relief valve to check is the Combi System Relief and Diverter Valve. It appears to be OK after removal and inspection. I did however encounter a small bit of metal debris about the size of a large grain or two of sand when I cleaned it out. I'm beginning to suspect some kind of contamination and blockage in the Relief valve(s) located within the 3 PT. system. Any relief valves that are within the 3 Pt. Assy. will have to be checked by the dealer as I just don't feel comfortable opening her up without a garage to keep out of inclement weather not to mention this would really test my mechanical aptitude.
In my flow tests, I got 15 OZ. of fluid from the power beyond hose and 9 OZ. from one of the FEL hoses. I have to keep in mind that the Power Beyond Hose is twice as thick as one of the FEL hoses. It appeared to be quite easy to stop the flow from the Power Beyond Hose. So I've got flow but no pressure.
In the Troubleshooting section of the manual, I looked for common points between "Implement fails to lift" and "Implement rises to slowly". They are as follows:
1. Bad Saftey Valve
2. Bad Hyd. Pump
3. Oil Leak Past Lift Cycl.
4. Restricted Suction Folter
5. Control Valve Plunger Stuck Open
6. Lowering Valve Spool out of Adjustment.
Non Common Points include:
1. Linkage Adjustment
2. Relief Valve Setting Too Low
3. O Ring Failure at Valve Body to Cover
4. Bad Relief Valve.
With that in mind, I think we can eliminate a Bad Hyd. Pump as the FEL works just fine (Can lift a full bucket of sand/Dirt etc...There is no suction filter in the 1920, only the 2120, eliminating that cause. Control Valve Plunger Stuck open doesn't ring true as I can control the rate of 3Pt. arm descent with the control valve. That leaves 1, 3 and 6. I would also include potential blockage in the Hyd.Control Valve and/or the Flow Cntrl.Valve, both of which are contained within the 3Pt. Housing Assy.
At this point, and after discussing with the NH shop last Thursday, I will bring the tractor down to the shop and let them take it from here. They'll charge me $61/Hr. and are just as stumped on this as we all are so they've taken this as somewhat of a challenge. Perhaps they'll go easy on my checkbook but I need to get it fixed.
Any thoughts at this point?
Todd in Placerville
/ Perplexing Hydraulic Problem #30
I'm still convinced it's an oil leak due to a busted seal or a stuck relief/safety valve...but I lost all my money on St. Louis in the Superbowl, so I'm too broke to bet./w3tcompact/icons/laugh.gif
I agree Jinman. I think it's a safety valve stuck inside the Hyd. Control Valve which is inside the 3 Pt. Assy. hosuing. And I've already said that would stretch my mechanical aptitude at this point not to mention no garage, no hoist to lift the top of the assy., no time, etc...
I reviewed the flow of fluid and I thought it flowed from Pump to Diverter to FEL valve when in fact it goes Pump to Diverter to Hyd. Control Valve. Stuck Safety Valve in the Hyd. Ctrl. Valve. That's my guesstimate.
Todd in Placerville.
/ Perplexing Hydraulic Problem #32
Any update on the problem? I'm especially interested as I have a NH 1920 also. Thanks
Billfires
Thanks for asking Bill. I dropped the tractor off at the NH shop on Monday. Spoke with them today and there was 0 pressure from the Power Beyond rearward, hence no lift on the 3Pt. unless running 2500 RPM's and even then you could stop the ascent with little pressure with your hand.
They are testing the Pressure Relief Valve in the frams mount diverter and then there are two or more safety valves to check under the seat. We'll see what they come up with.
Cheers.
Well fellow TBN'ers, I've got the 1920 back from the shop and they even had trouble finding the problem. It turned out to be an internal bolt in the two spool remote valve (the valve controlling the FEL and providing power beyond). This bolt had worked it's way loose and was allowing the fluid to dump directly back into the reservoir while still enabling the FEL to work.
Upon inspecting this bolt (allen type) it appeared to have been slightly stripped on the first thread and we don't know if that was a factory issue or if it happened as it worked loose.
Nonetheless it cost me a bit of money to isolate and repair this 25 cent part. My initial thoughts were that the problem was somehow in this valve as nothing worked past it but I was reticent to open it up and explore. My common sense now tell's me not to be so gun shy as had I had to have them rebuild the valve, it probably would've cost less thant the labor to find it and fix it.
Thankyou for everyone help and input. Todd in Placerville
/ Perplexing Hydraulic Problem #35
<font color=blue>My common sense now tell's me not to be so gun shy as had I had to have them rebuild the valve, it probably would've cost less thant the labor to find it and fix it.
</font color=blue>
Don't try to second-guess yourself, Todd. Most problems are perfectly clear once we discover the real cause. You could just as easily have disassembled the remote valve and have it turn out to be somewhere else. I'm happy you found the problem and now have your tractor back on the job. /w3tcompact/icons/smile.gif/w3tcompact/icons/grin.gif
Thanks for letting us know what happened.
/ Perplexing Hydraulic Problem #36
Todd, thanks for the update. Sometimes when it comes to repairs it's hard to figure out the best course of action. If this had been something the shop had seen before it might have been a quick repair but it seems in this case they didn't find it any faster than you could have. Glad it's fixed and thanks once again for keeping us informed.
Bill
/ Perplexing Hydraulic Problem #37
Todd, a little off the subject but have you had the "cool running" problem on your 1920? I was able to put my first operating hour on mine and noticed the temp gauge barely moved.
Bill
Well, It's nice to back on a fully functioning tractor. I've used the FEL and the Backhoe post fix and one thing I've noticed is that both the FEL and the Hoe respond more smoothly since the two spool valve was repaired. I had begun to notice that the FEL was getting a little jerky, particularly going into and out of float-It wasn't smooth and the hydraulics would jump around when utilized. Also the Backhoe now provides me with a much greater/granular degree of control in movement whereas it was also more jerky prior to the fix. I guess as these things started to manifest themselves, they went unoticed due to :
1. This is my first Tractor/Hydraulic machine
2. Changes were gradual as opposed to instantaneous. If you read one of my first posts, you'll note that the Backhoe stopped working slowly as opposed to all at once.
All in all, I'm now a happy camper once again. And thankyou once again for all the helpful TBN'ers that went down the diagnostic path with me. Truly a remarkable resource this little website.
Todd in Placerville
/ Perplexing Hydraulic Problem #39
:thumbsup:
I have a 1920 New Holland tractor also. My neighbor and I just fixed the same issue. The lift would not work but the front end loader would. I found this statement ya'll were talking about and the same set screw had fallen out. It is on the double spool valve. Sitting on the tractor with the blue cover off the valve, it will be the cap you take off with a wrench on the left side of the valves. Take the screw cap loose and inside there is where the allen screw should be tight. Mine was just lying there. It looked like it had Loc-tite on the threads but it had backed out. We put Loc-tite on it and tightened it down. My lift works great now! Thanks for the info! Also thanks to my neighbor Greg B. and his uncle Gary B. in PC VA.
/ Perplexing Hydraulic Problem #40
Weekend warrior,
Welcome, Glad your problem is fixed.....Possible to get some pics of the culprit for the next guy..??
