People with 3 pt hoes/ TLB's
   / People with 3 pt hoes/ TLB's #21
I've owned my tractor with a subframe backhoe for over 15 years so I don't remember what the additional cost for the backhoe was. I probably couldn't even justify the cost of a tractor at the time, but isn't that the case with most toys?? Anyways, I love having the backhoe. I've dug out dozens of stumps with it, including some so big that the hardest part was getting the free stump out of the hole. I'd rather use a backhoe than a shovel anyday.
   / People with 3 pt hoes/ TLB's #22
Redneck -- do a search for 3pt hoes vs. subframe and after reading the volumes of threads on the subject....I believe you'll come to the conclusion, like I did, that a subframe (at any cost) is the only way to go. After using mine on stumps....it was very obvious that I needed that extra support.
It all depends on the size of your tractor. For all the small tractors (let's say in the New Holland line TC55 or smaller) a subframe is essential. For larger machines like my TN75D a 3 pt works out fine when it is attached with rugged 3 pt solid bars like mine.
Andy
   / People with 3 pt hoes/ TLB's #23
Is this a larger tractor/backhoe? Care to share your techniques? I haven't been so successful in digging/breaking the root systems on anything but smaller stumps. (But I just have a small Kubota B21 TLB).
Ken
   / People with 3 pt hoes/ TLB's #24
There is another option out there.
Called a 'tow hoe' or 'cricket'.
It has legs near the bucket arm with wheels at the other end that swap positions for towing from site to site.
It digs as deep and as fast as a backhoe attachement but is slower to move about.
To move it around you jack the legs off the ground amd pull yourself with the 'stick' using the hydraulics.
Once proficient you literally hopity hop all over the place and dig quite rapidly.
Great for trenching runs but difficult to work close to , example, foundations.
Very stable and probably more so than backhoe on a CUT due to low C/G and wide stance.
I have trenched water lines in areas that I never would dare to drive my CUT.
While great fun and very useful, it sits under a tarp and have not used it in 4 years.
Sure glad that I did not invest heavily.
Big downside is that since it is 'bucket propelled' it tears up the grassy areas real bad so that it is only a 'unfinished site' tool.
Before mini excavators it was a very popular rental unit around here and still great for trenching hedges.
Don't ask for pics as it lies under 4-5 ft of snow(and tarp).
   / People with 3 pt hoes/ TLB's #25
My 7.5' frame-mount hoe cost about $6K USD when purchased with the tractor. I would say to date (~150 hours of hoeing) it's probably paid for half of its cost. I've installed septic lines, buried a 500 gallon propane tank and trenched for the lines to house, buried gutter drain tile, dug footers for a retaining wall, installed 40' of 2' diameter culvert pipe, dug a garden pond, removed several large stumps, placed a heavy concrete fountain in the garden pond, removed all the old shrubs from in front of the house, buried the neighbors dog, buried a dead deere. Have other projects planned for it this spring too. Need I say more?
Will it ever fully pay for itself? Maybe, maybe not. But I chose to buy one because it's convenient and fun to do yourself without rental and transport hassles, and it really saves your own body too.
I have not been paid to do anything with it, and don't plan to ever try. I will ocassionally help out a neighbor or friend, but that's it. Didn't buy it to make money.
...buried a dead deere :D You probably meant 'deer' but I like the suggestion...
   / People with 3 pt hoes/ TLB's #26
LOL. Well maybe if his equipment is not green, he meant what he wrote:rolleyes:
Ken
   / People with 3 pt hoes/ TLB's #27
For that kind of money you might find a used true industrial TLB.
You would have a stronger and larger backhoe plus a tractor with bucket. I would love to have an excavator, but that is pretty specific and IMHO not as versatile as a TLB. But for specific needs it can't be beat. On the other hand, there are some excavator trenching and stuff that can be done with a backhoe or even a 3pt backhoe. Just not as efficiently. In my case I have a small 3pt backhoe and I wish it was larger. But nevertheless, I have done all kinds of projects and over the last 4 years, I'm pretty sure it's paid for itself. It's there anytime a backhoe project pops up ... no planning for rental time, just hook it up and use it.
The biggest drawback to renting is the time and effort to get the unit from a distant source over to my place.
It's pretty far away from the nearest city that has rental yards. Your situation may not be like that though. Even so, just having to arrange the time, phone calls, pick up and delivery are a waste of time in my case. Plus whatever you spend on rental is gone forever. Sure your particular project gets done but when another pops up you either neglect it or put it off until you can make time for the rental thing. Pretty soon, if you have enough projects, it adds up to the same amount as the purchase. What you'd have then is your projects complete but no backhoe.
The biggest drawback to hiring it done is similar. Project gets done and you pay for them.
Other projects come and same thing occurs as above. Enough projects hired out and you spent more than what you could buy the backhoe for but left with no backhoe. In purchasing one, you have your projects complete PLUS the backhoe. Convenience is a HUGE factor in my opinion and having one around is ideal. If your projects are ones you can do on weekends you won't lose work time. It just takes longer.
You will need to make time to use it, but if you're considering renting you still have to do that. Overall, if you can swing it, buy the backhoe and do the work yourself. It might take you longer, but you end up doing it no matter what and you have seat time. You learn a lot too. After my Log Home was completed, I haven't used my backhoe that much. But for all the trenching, footings, rock removal, etc, I saved a fortune doing that myself...maybe 3 (or more) times what I paid for my little 8' Nardi 3pt backhoe. Now I still own the backhoe. I just put it on last week to remove two large Oaks digging them out. So there is always something that pops up. You won't be sorry to own one.
Just make sure it's of adequate size.
   / People with 3 pt hoes/ TLB's #28
Ken
Freudian slip. I meant deer. Couldn't be Deere, cause they never die!:D
   / People with 3 pt hoes/ TLB's #29
Ken
Hi Ken,
Mine's a smaller tractor, a Ford-New Holland 1620 (27HP). No special technique, just keep digging around the stump, breaking the roots I can with the backhoe, exposing the bigger ones and cutting those with a chain saw. Eventually everything breaks loose.
   / People with 3 pt hoes/ TLB's #30
When I bought my tractor, the salesman actually tried to talk me OUT of buying the backhoe. He said most people don't use it enough to justify the expense. I had to appreciate his honesty, but I bought it anyway.
I had a trenching project that needed to get done and I figured a contractor would have charged me at least half the price of the backhoe (about $6,000 when I bought the tractor as I recall). So, I figured the first job would pay for at least half of the backhoe and I would still have it for other projects (and I have used it sporadically since - mostly it sits).
I have an ongoing project to control surface water drainage across my property that I work at when I want to. I could never have this luxury with a rental unit. Renting is all rush rush rush to get your money's worth. I work at my own relaxed pace, and if a deer walks by (not a Deere!) I stop and enjoy the experience. In short, I enjoy the "work" much more than if I rented. It's not the destination, it's the journey.
One thing the salesman did talk me into was a subframe. I wanted a 3PH backhoe, figuring I could sell it more easily. He talked me into the subframe, and I'm glad he did - the stresses are tremendous.
I haven't hired out with the backhoe, but I have thought about it. The small size could be an advantage getting into backyards and such, but I wish mine dug deeper. The mini-excavator is a great idea if you can find one for the right price. But, if you need a loader on the job (say for hauling and placing drainage stone, etc.) you would need to make a second trip to go get your tractor - that bites into your profits.
Streamin - switching over from 3PH to the backhoe is fairly easy after you do it a couple of times. The hardest part on mine is finding a wrench to remove two bolts holding the 3-point arms in. The rest is pulling pins. The back hoe connects very easily - you hook up the hydraulic lines first and use the backhoe itself to maneuver it into position. Once in position, you slide in the pins (I'm sure I'm not using the proper term here) and you're done. I'd say 15 or 20 minutes from one to the other. It helps if you have put the backhoe on a flat and level surface when you stored it.
- Marty
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
