Pension enhancement
/ Pension enhancement #1
metalbender
Sask, Canada
Massey 1742
A little gig I have going with a local glass company. Welding deck posts for vinyl deck rails. Drill four holes in 1/4 thick plates and weld to galvanized pipe. Lots of ventilation required. Did 28 today. Finish with a shot of cold galvanize coating. Drilling jig and home built rotary table makes things easier. Have done hundreds. 1469AA8F-1AAD-4731-89E4-A3BD1B6122A9.jpeg893EF0DE-6AFA-4D48-9462-1DFEF92A41B1.jpegA20CED05-5C2F-43CC-9039-73942120B188.jpeg
Getting older and slowing down. Five or six years ago I could do eighty in a long day. Weld time is about a minute on the table. A jig on the table clamps the pipe in the correct position. Three spots, loosen clamps and turn on the table.
/ Pension enhancement #4
That is a pretty neat gig. The fit up and welding is easy (need good ventilation) but the drilling would be time consuming. How much do you get per piece? Do they furnish all the material cut to size or do you have to do that also?
/ Pension enhancement #5
At the fence company I worked at we'd get 6x6 and 8x8 plates already punched and dipped, 10 to a box. Grinding off the galv to weld was always time consuming and ate a bunch of discs, so I bought a rotary table and built a fixture so I could cut circles out with a half inch mill. I'd set up and do a couple boxes for 1.625" posts, some 1.875" and 2.375"
Here they are on page CL-122 of the Master Halco catalog.
The plates seem to be laser cut, pipes are cut to length. The drilling jig works without clamping, drill reposition and repeat. I use my Grizzly G0720 bench mill. Drill 7/16 hole without pilot, one shot. Just over a minute per plate. Table does one rpm, welding time. Using flux core, buff with a knot type brush, another minute. Lay them on a rack, roll the pipes while giving a shot of Rustoleum cold galvanize coating spray. Five minutes to spray 20. The hard part is moving the darn pipes five times. Turned 69 this year, slowing down. Doing it for $ 8.00 per pipe, roughly $ 50 or so an hr. depends how energetic I am that particular day.
/ Pension enhancement #8
Seems like a whole lot of work. Can't you just loot the local TARGET when the opportunity presents itself?
I kid of course. I salute you and your industriousness.
Yup, an ironworker would make the holes quicker. This is just a part of the metal hobby that actually pays. BIL, has been with the glass shop thirty plus years, asked years ago if I could "weld a couple of plates onto pipes" So it began, told him if it becomes a job, not going to happen very long. Have done hundreds over the years. Lots of work? Yup, not continuous though and on my schedule.
/ Pension enhancement #10
It's always interesting to me, that a guy like you can make a busniness, often on the side, and create demand. Someone else spends a fortune opening a business, they are "SURE" will prosper, only to loose their shirt.
Not a business, just a hobby with a skillset that happens to be in demand. Along with a bit of machine work thrown in for good measure.
/ Pension enhancement #12
:thumbsup:
/ Pension enhancement #13
Very nice. Any pictures of what the finished product looks like at a clients home?
/ Pension enhancement #14
Not bad, I would think that drill time would eat up most of the time to complete. I certainly couldnt drill 4 ea. 7/16" holes in less than one minute per hole. I would have to use a pilot hole with my little cheapy drill press, I am thinking about 2 minutes per hole. Welding time about a minute and a half, 10 minutes per post minimum. But if I got a money project, I could invest in a good drill press to cut that down to like your estimated time.
You could switch to MIG and then skip the buffing.
Drilling with my jig in the mill is quick. Long story on the electronics on the mill crapping the bed, but replaced the motor and electronics with a three ph and VFD. I don't grind off the galvanizing on the pipe, mig with gas doesn't work with it so flux core is used.
Don't have any pics of their work, all professionally done.
/ Pension enhancement #16
Very nice work and good solutions using what you have
BTW reading from my iPhone screen I thought the thread title said ***** Enhancement at first glance.
What you want to see is a bit different than what you read. Funny how the mind works.
/ Pension enhancement #18
I will take two...........:laughing:
/ Pension enhancement #19
Well at least my mind read it as enhancement.....(was thinking along the lines of a tan or slimming down) and not ENLARGEMENT.
/ Pension enhancement #20
Are we going to see a new set of tv commercials with “Smiling Big Barn”?
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
John Deere 3025E (A64126)
John Deere 3025E...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
