Forks Paynes Forks
/ Paynes Forks #2
They work if you rarely need forks. I bought a set and returned them as too dangerous. Stuck out too far so lift capacity was very reduced and they swiveled dangerously just when you least expected it. I got QA Woods forks and love them.
Andy
/ Paynes Forks #4
I noticed that they had light, medium and heavy duty, which ones did you folks have? Maybe that has something to do with the like/dislike factor. I am also looking for forks. I won't need them often, still deciding between bucket forks and QA forks.
/ Paynes Forks #5
I got the light duty set because.
A~They are lighter to lift handle and install/take off.
B~They are plenty strong enough to handle anything the BX23 Fel Can lift with out bending the forks.
C~It just didn't make sense to get the heavier medium or heavy duty forks and reduce the lift capacity of the FEL
== L B ==
/ Paynes Forks #6
I bought a set of Sundown forks when I got my tractor, very similar to the Paynes units. As AndyMA said they do stick out quite far and reduce capacity. I use them most for moving brush and short logs etc. I could have got what they call trash forks instead and have regreted it ever since. I may palletize next years firewood so maybe they will serve me better for that.
If money isn't a prohibiting factor go for the real QA forks they will be waay more capable. Just my 2cents.
I am looking into converting to a QA setup for the loader then everything will be QA.
Ayuh
/ Paynes Forks #7
I too have a set of paynes light duty forks and find them very usefull.
I use them to move firewood weekly, have moved logs (usually keep them around 10'), brush.
The downfall is they do tend to turn but I have never lost a load because of it.
The other downfall is you lose visibility from the fel.
I have a tooth bar and find that it stiffens the fel edge so there is less of a chance of bending.
/ Paynes Forks #8
Matt_W said:
it.
Some times I stand up and peek over the bucket just enough to see the tips of the forks when they are on the ground.
For stacking at times I peer under the bucket to see where the forks are and determine where they need to go?
Have you tried either of these methods.
Usually works pretty good for me.
:cool: == L B ==:cool:
/ Paynes Forks #9
If you have a lot of farm or used equipment auctions in your area you can maybe you can find some decent used forks to adapt. That's where I got mine. The only thing I bought new was the hooks, pins and reinforcing straps from JD.
M.D.
/ Paynes Forks #10
Found myself using both of those tips.
Standing up is sometimes hard because of the seat belt.
When the fel is up high enough peeking under seems to work great.
I keep my wood racks on top of pallets so that helps keep them up a little.
sometimes I tilt the forks upward or downward to align but then before you push you have to level them again.
great tips though!
2025 Poly Fuel Tank with Electric Pump (A61568)
2025 Poly Fuel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 FREIGHTLINER CASCADIA (A60736)
2009 FREIGHTLINER...
DOOSAN 5K FORKLIFT  G25P-5 (A60736)
DOOSAN 5K FORKLIFT...
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
