Pave Your Own Driveway?
/ Pave Your Own Driveway? #21
Yes, fiber and wire do different things.
Concrete is very strong in compression, but relatively weak in tension. Properly rebar reinforced concrete is twice as strong as unreinforced concrete. The compression happens when a heavy truck passes over a well compacted, deep base. The latter happens when there is a lack of support underneath, and the concrete flexes downward, like a beam in a building.
Glass or plastic fiber helps with surface cracking and spalling, especially during drying. It doesn't add much strength to the final concrete. There are spiral steel "fibers" that are sometimes used as a strength additive, but even more than glass or plastic, the steel fibers tend to clump during mixing, which does away with their strength. It is very technique driven, and dependent upon not having water on the surface, I.e. ok for a warehouse floor, but not for a driveway, especially one that gets salt.
Rebar, 3/4 of the way down on lots of supports (chairs, preferably plastic or concrete), wired together so that it does not get stepped on and pressed to the bottom, acts in tension to support the concrete and helps reduce cracking caused by heavy loads or a poor base, or, say ground squirrels.
Lots of information here; Concrete Rebar: Everything You Need To Know [plus 8 Main Types]
@Creamer In answer to the original question, this doesn't sound like a DIY job to me, and as others have mentioned, I think that the pricing is off.
For DIY, in addition to pouring, concrete requires good surface work (floating) to milk more cement to the surface to make a harder, more water impervious layer at the top. You need to be doing that at the right time after pouring when the concrete has just set enough. Concrete waits for nobody.
As @Have tractor will travel mentions, you could break it up into small 12x12' chunks, but why demo out a reasonable asphalt base? I would level up the base, tar it, add fabric (geotextile), tar it again, and pave with 2+" of new asphalt. If you are worried about loads, talk to your asphalt supplier and get base asphalt put down which has a coarser mix of gravel, but is stronger. Repave with a second layer of finish asphalt in a year or two, if you want a supper smooth driveway.
All the best,
Peter
Be sure to read this at least twice. Maybe a few more times if you are thinking of using wire or fiber instead of rebar. Keep reading it until you realize that rebar on chairs is the only way to do this correctly.
More important the rebar, is how much water is added to the concrete. Water creates volume. When that water evaporates, the amount of space it took up goes away, and the concrete cracks. Big cracks are from too much water. This happens in the first couple of days and it has nothing to do with the soil under it, or what was used to reinforce it. There is a slump test that can be done with a small plastic bucket to see if there is too much water. But basically, you want the concrete to be able to hold its shape to dome degree, and not be like soup. It is a lot more work and effort to work concrete with the correct amount of water, so most contractors will add more water so it flows easier.
The driveway does not need to be 12 feet wide. Ten feet wide is plenty to drive on with room on either side.
Because concrete expands when it's hot out, and contracts when it's cold out, expansion joints need to be big enough to handle this. You have to pour a driveway in sections so it can expand and contract.
Asphalt allows you to have a smooth surface the entire length. It fails at the edges and where heavy vehicles make turns. Going wider with asphalt will allow more strength so it lasts longer. 12 feet would probably be better for the width, but it's a massive expense when 10 feet works most of the time.
There are different mixes in asphalt. One of my clients runs an asphalt plant and the County and Highway mix is a lot different, and more expensive, then what some companies use for driveways. When there is a huge project going on, they will only have the County mix available, and that drives up the cost considerably. You also get a much stronger road if you use it. There are paving companies out there that charge you a set price for the driveway, and then order the cheapest mix possible. The home owner rarely knows the difference and thinks that they are getting the same thing that the roads are made of. Be sure to know what mix of asphalt that you are paying for, and if a better mix is available.
When it's all said and done, paying a pro to do it correctly is almost always the cheapest way to go. If you do it yourself, the learning curve is very long, painful and expensive.
/ Pave Your Own Driveway? #23
I helped my uncle pave his 400' long, 10' wide drive with concrete a few years back. We formed out 10' x 12' sections on a packed gravel base with 2x10's and used rebar to tie the slabs together. We did two or three slabs per week weather permitting. It took most of the summer to complete but it turned out well.
I was planning on doing my drive the same way but decided against it. I need to use cleated tire chains on my tractor to plow my steep 1.5 mile gravel private road. The chains chew the heck out of any paved surface. Besides, it made no sense to pave the last 400' of a long gravel road.
/ Pave Your Own Driveway? #24
Forgive me, but I thought asphalt was all the same. What are the mixes you speak of?
/ Pave Your Own Driveway? #25
No asphalt is not all the same. I’m betting most companies that make asphalt have 6 mixes or so they use on a regular basis. For example, leveling binder, base course and surface course would be common mixes used in Illinois on road projects. Base course would be the first layer down, and there is often two layers of that, and then topped off with surface course.
/ Pave Your Own Driveway? #26
The only problem I see is when using mesh. It must be on stand-ups, otherwise it lays on the bottom and won't work to keep cracked sections together.
/ Pave Your Own Driveway? #27
25 years ago I had washouts on my hilly drive and brought in 3 truckloads of recycled asphalt that we compacted with the dump trucks wheels.
I did say 25 years.
Only this year did I need to do repairs* and nowadays they shred it so it is much easier to spread and compact.
Best of all, recycled is a tad cheaper than crushed stone and IMHO, easier to do a nice job than concrete certainly with a CUT and minimal and raking.
The hot sun does the rest.
*mostly due to frost heaving buried rocks that we neglected to remove.
With recycled asphalt a good truck driver can lay it down to whatever thickness you desire.
/ Pave Your Own Driveway? #28
I did say 25 years.
Where would you get that? Do you need to know somebody at the state DOT and/or be in the right place at the right time when they're re-paving in the area?
Definitely something I'd consider if it ever came to paving my driveway. 25 years will likely outlast me.
/ Pave Your Own Driveway? #29
When existing pavement is overlayed they often use a device called a rotomill. It grinds up some of the existing pavement and levels it out. It usually dumps the millings into a dump truck on a conveyor. The contractor often gets to keep this material or sometimes it gets added to new asphalt. It ends up looking about like gravel but still has a lot of asphalt in it.
/ Pave Your Own Driveway? #30
Now days the gravel pit/asphalt plant has it always in stock.
Actually in 2 grades, one being as is shredded and the other has some additives for better binding.
But then I'm rural and know most truckers and contractors.
I'd guess that most truckers should know how and where to get some recycled in your area.
Most cases recycled will be cheaper than crushed while cartage won't change.
/ Pave Your Own Driveway? #31
Where the heck are people getting concrete anywhere close to $100 a yard on a truck? $170 here.
Concrete will not go thru an asphalt paver. It will not flow out to the edges.
I was finally going to surface my gravel drive this year, 45’x70’. After the sixth bid, 3 bit, 3 crete, I gave up and said maybe next year.
/ Pave Your Own Driveway? #32
Some thoughts.
OP says the neighbor/library is doing their portion in blacktop. Would the concrete trucks have to pass over that portion? In many places they won't do that without a signed waiver. Would the library sign a waiver for their new blacktop?
Concrete fails in fire. Lots of roads, bridges and even building foundations have to be redone after a major fire. Would that warranty (likely made in jest) apply?
People often mention reclaimed blacktop on these threads. It isn't available everywhere. Many plants roll it back into fresh mix, so they refuse to sell it.
/ Pave Your Own Driveway? #33
Yep, you got it.
Back then it was dumped but now days of recycling it has become a desirable commodity.
Often road builders will simply shred the old asphalt, compact it in place and add a new layer of fresh asphalt as a topping.
/ Pave Your Own Driveway? #34
Where I worked they would sell it and it made a good stable driveway, but it would track. They had mountains of waste asphalt that had been dumped by contractors that was awaiting grinding down to make what they called "recycled asphalt product". The best time to buy it was early spring before paving season. They would grind it in the off season and it was used to augment certain mixes of asphalt.
Some people have used fresh ground asphalt straight from the resurfacing project, but I am not fond of it myself. I've seen the stuff in my truck that was too chunky, 3"x5"x 3/4, and other loads that looked about like hot mix asphalt except for the temperature,
Some thoughts.
That is the exact problem I have locally. I have to find it when road construction is being done in my area and the contractor has to find a place to put it. The local plant mixes it back in and is always looking for it was well because they sell it in the mix at almost full price.
Some thoughts.
The library has set up their asphalt to handle the large trucks like the garbage truck, semis that I have come in regularly, and rock trucks for my driveway, pond, etc.
I was quoted $118 a yard for 5 bag mix delivered with no waiting.
/ Pave Your Own Driveway? #38
It’s around $120 here plus tax for the lowest PSI mix. And there’s a 4 yard minimum for free delivery.
I think you're severely underestimating the cost of enough concrete to do a 1/4 mile long driveway 12' wide by 5.5" thick.
I only have to do half of the 1/4 mile long driveway which is where I got my numbers from. Sorry about the confusion.
I calculate 315 yards of concrete to do a 1/4 mile 12 foot wide and the 2700 square foot pad. That’s way more than $17,000 of concrete. More like $40,000 worth. Aside from that attempting to DIY it especially through a paver is an awful idea. If the driveway is already asphalt why would you demo it? Just put down another 2” on top. You’d save the cost of demoing and hauling away which in itself would be expensive and you’d cut the material in half.
Because the asphalt area is already even with the garage floor height and consequently I have some poor drainage that I need to fix when I do this. Now the Asphalt is almost level with a few dips that doesn't drain well which means when it thaws in the winter some places are nice and others are small ice rinks spread intermittently all over the paved area.
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
SKID STEER LAND LEVELER (A60430)
SKID STEER LAND...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
UNUSED IRANCH 23" GRID SHAPED MINI EXCAVATOR BKT (A60432)
UNUSED IRANCH 23"...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
