Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #91
Re: Pat\'s Easy Change System - Order Online!
Has anyone used this type of quick hitch. Since you have to get off the seat anyway to release and for the top link with Pat's, I do not see too much of a disadvantage with this one.
Rich
Quick Hitch
   / Pat's Easy Change System - Order Online! #92
I think the main advantage that Pat's has over that one is the set screws to align the hooks to the the desired angle.
   / Pat's Easy Change System - Order Online! #93
I guess I may be the only one in the world with a problem with Pat's hitch. I installed it on my Kubota L3400, but now find my toplink is too short for my cutter to sit level.
Has anyone else found this to be a problem?
Where can I find a reallllllly long toplink???
I had to remove the hitch and go back to the old fashioned way of attaching implements.
If I cannot find a solution, I guess my hitch may be making an appearance on ebay! /forums/images/graemlins/mad.gif
   / Pat's Easy Change System - Order Online! #94
A farm and home store, Orshlans, TSC, Farm & Fleet, should have a selections of top links in various lengths.
   / Pat's Easy Change System - Order Online! #95
I put the Easy Change on my Kubota 3130 this morning and I love it! Box blade on in a couple of minutes, then hooked up the bush hog in record time. I've told 2 of my friends about this, and next to the front end loader, this is the handiest thing I have for my tractor.
My toplink is out a good way too, but I leave the front edge of the bush hog angled down a little anyway. PTO worked fine. The boxblade is level. I read the posts here a lot and finally ordered a set. I recommend this to anyone that changes implements frequently.
And about the posts in reference to the instructions: Mine were fine. Read them and hooked it up no sweat in a little less than an hour (including getting the tools).
   / Pat's Easy Change System - Order Online! #96
Glad you have had good sucess with them. I bought mine a few years ago at a show and I couldn't be happier.
I got to meet Pat and his staff too.
The only thing they won't work with is my Japanese tiller. I'll work that one out soon.
   / Pat's Easy Change System - Order Online! #97
Is there any version of Pat's Easy Change System (or another quick-change system) that is compatible with Category II implements?
Thanks all,
Grant
   / Pat's Easy Change System - Order Online! #98
Yes, Pat's comes in a Cat II version as well.
   / Pat's Easy Change System - Order Online! #99
Has anyone used Pat's system with a B series Kubota and a 5' Landpride rotary cutter?
Just trying to figure out whether I'll need a new top link and/or a PTO shaft extension.
The cutter is all packed up for winter and would be a PITA to pull out ... thought perhaps someone else might have this information - sparing me the PITA.
/forums/images/graemlins/smile.gif
   / Pat's Easy Change System - Order Online! #100
I'm considering the Pat's system vs. the Worksaver QH.
Little concerned about the installation instructions of the Pat's as it sounds like it can be a pain. Have the instructions improved?
How about the issue with the toplink that niner was talking about - is this a common issue - will I need a new toplink?
Anyone use this successfully on their L3400?
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2018 John Deere 4066R (A53314)
2018 John Deere...
Yamaha (A55758)
Yamaha (A55758)
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
