Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #101
Re: Pat\'s Easy Change System - Order Online!
</font><font color="blue" class="small">( Anyone use this successfully on their L3400?
)</font>
I have a 3400 and several implements. I haven't installed it yet; probably do it this weekend.
I'll post my results, including if it works or doesn't work w/ certain implements.
   / Pat's Easy Change System - Order Online! #102
Look forward to hearing form you investorguy!
   / Pat's Easy Change System - Order Online! #103
Installed it today. Took about 20 minutes at the most.
Then I backed up to my BB, lowered my 3ph, backed up a bit more and *bam* connected. Hooked in the Toplink and I was golden. Now I just need a hydrolic toplink.
My wife never comments on the tractor, but when she saw how easy it was to hook up the BB (and remembered how I have fussed w/ it in the past) she said, "why don't all tractors just come that way?"
that should be enough.
   / Pat's Easy Change System - Order Online! #104
Thanks a bunch investorguy. Does not sound like the length of the top link was an issue for you at all.
I'm getting ready to place my order next week. It's cheaper than the Worksaver QH I was considering, doesn't require adapter bushings and leaves me open to picking up the odd used implement and using the neighbours borrowed implements easily.
Thanks a bunch again!
   / Pat's Easy Change System - Order Online! #105
Anybody know if Pat's makes a set for a TC 48DA (Cat II hitch). If not, anything made by someone else that's similar for Cat II's?
Thanks.
Andy
   / Pat's Easy Change System - Order Online! #107
I have a Kubota L2800 HST. Will the easy change work on it? The instruction says it need 4 inches straight. I have only 2 inches from the center of the hole to the start of the bend. Some of the post indicate it works in some cases with less tha 4 inches. It sounds like a great idea. my new tractor is a pain to hook up.
   / Pat's Easy Change System - Order Online! #108
I emailed greenwell and they said it would fit as they has several happy customers with the easy change installed on their L2800.
   / Pat's Easy Change System - Order Online! #110
2manyhorses said:
Hate to sound stupid, but is the $179 for a pair?:eek:
Not a stupid question at all. :)
Yep, that price is for a pair.
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
