Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #151
I have used a pair of these for two or three years now, very useful and easy to use.
   / Pat's Easy Change System - Order Online! #153
Anyone out there using a drawbar with there Pat's QH? What type of drawbar lock are you using? Any ideas for fabricating your own? Thanks
   / Pat's Easy Change System - Order Online! #154
I've put one of these on a MF GC2310 and it fits and works real nice. Allows me to connect to TSC Kinc Kutter 48" Tiller - wasn't able to with out it.
Now I need a simple solution to keep the arms spread aparts before hook-up. Anyone try bending both ends of a threaded rod? I wonder if the rod would snap when bending.
   / Pat's Easy Change System - Order Online! #155
Does Pat's sell replacement springs????? All of mine are broke and I have to keep them locked down with baling wire.....Still love them though!!
   / Pat's Easy Change System - Order Online! #156
Mike120,
Contact me with your information and I send you the springs and hardware to replace.
Pat of Pat's Easy Change.
   / Pat's Easy Change System - Order Online! #157
N1ST,
You will probably be ok. Same principle as the stabilizer bar, only it is adjustable. It is $28.00 if you are interested.
   / Pat's Easy Change System - Order Online! #158
Sounds great, will it work on older 3ph (MF135), and does the top link have to be longer to make up for lower arms being moved back a little?
   / Pat's Easy Change System - Order Online! #159
Masseyferboy,
Yes, works fine on MF135. It does extend your lift arms 3-1/2" to 4" so make sure your top link has that much extra or you can always pick up a longer one at TSC.
Thank you
   / Pat's Easy Change System - Order Online! #160
I recently purchased an 07 Kubota 4740 with the telescoping 3 pt arms. Is Pat's compatible with this model?
I've found a "cheaper" model in Texas, but is a cast iron model.
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
