3-Point Hitch Pat's Easy Change on a L5030
   / Pat's Easy Change on a L5030 #11
ditto what TripleR said.
Pats fits on my L5030 just fine, no problems.
I use the original style which extends the 3pt arms some.
This is the style I need...I have a hay fork...the style that sticks up above the existing arm would not fit on my hay fork. Check your implements to see if you have
All my several pieces of equipment work with the original style easy change.
I have cat II purchased directly from Pat and use bushings on my Cat I implements.
Have had them for several years. Had one spring break..called Pat, he sent me replacement springs immediately. Great to deal with. Excellent attachment. Had them for maybe 4 years.
   / Pat's Easy Change on a L5030 #12
I don't have these but have wanted them for years.
If John says that they are good, you can bank on it.
   / Pat's Easy Change on a L5030 #13
Can you get a set that just replace the extendable links in the lift arms?
   / Pat's Easy Change on a L5030 #14
slow,
From what I have read at Pat's site, yes. But then they do not telescope since they do not need to.
   / Pat's Easy Change on a L5030 #15
Yes, that is the kind I got, but as RFB says, they don't telescope. I haven't put mine on yet as I have my box blade on and it doesn't make much sense to go to the trouble of taking it off to put them on so it will be "easier" to swap equipment out.:laughing:
Thanks, TexasJohn. I'll just order the original style.
2002 Bobcat 763 Compact Skid Steer (A57024)
2002 Bobcat 763...
Year: 2014 Make: Volvo Model: VNM Vehicle Type: Truck Mileage: 281675 Plate: Body Type: Trim Level: (A55852)
Year: 2014 Make...
Tortoise Statue (A55853)
Tortoise Statue...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2019 JOHN DEERE 350G LC EXCAVATOR (A52707)
2019 JOHN DEERE...
2006 Ingersoll Rand P185 Towable Air Compressor (A55851)
2006 Ingersoll...
