3-Point Hitch Pat's Easy Change on a L5030
   / Pat's Easy Change on a L5030 #11
ditto what TripleR said.
Pats fits on my L5030 just fine, no problems.
I use the original style which extends the 3pt arms some.
This is the style I need...I have a hay fork...the style that sticks up above the existing arm would not fit on my hay fork. Check your implements to see if you have
All my several pieces of equipment work with the original style easy change.
I have cat II purchased directly from Pat and use bushings on my Cat I implements.
Have had them for several years. Had one spring break..called Pat, he sent me replacement springs immediately. Great to deal with. Excellent attachment. Had them for maybe 4 years.
   / Pat's Easy Change on a L5030 #12
I don't have these but have wanted them for years.
If John says that they are good, you can bank on it.
   / Pat's Easy Change on a L5030 #13
Can you get a set that just replace the extendable links in the lift arms?
   / Pat's Easy Change on a L5030 #14
slow,
From what I have read at Pat's site, yes. But then they do not telescope since they do not need to.
   / Pat's Easy Change on a L5030 #15
Yes, that is the kind I got, but as RFB says, they don't telescope. I haven't put mine on yet as I have my box blade on and it doesn't make much sense to go to the trouble of taking it off to put them on so it will be "easier" to swap equipment out.:laughing:
Thanks, TexasJohn. I'll just order the original style.
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2014 Kubota BX25D (A53317)
2014 Kubota BX25D...
VITRA FRESH PRO REFRIGERATOR W/ DRAWER FREEZERS (A57192)
VITRA FRESH PRO...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
Cart (A55853)
Cart (A55853)
