Pat's Easy Change - B7800
/ Pat's Easy Change - B7800 #1
MattBeef
SD
Pat\'s Easy Change - B7800
Does anyone have experience with this set-up?
From the product description, it seems that the "straight-line" on my lift arms are not long enough to make this work.
Any help / tips appreciated.
mlg
mlg
Re: Pat\'s Easy Change - B7800
None of you fellow B7800 owners have Pat's Easy Change? /forums/images/graemlins/shocked.gif
Interesting -- maybe this tells me I shouldn't buy a set, after all... /forums/images/graemlins/confused.gif
mlg
mlg
/ Pat's Easy Change - B7800 #5
I just installed them on my B7800 a couple of months ago and didn't have any problems. I can email or post some pictures if you think it will help.
/ Pat's Easy Change - B7800 #6
/ Pat's Easy Change - B7800 #7
I just installed them. They work fine. The optional separator arm is flimsy, but it does what it is suppose to. You still need to have something to keep the arms separated the right distance. Unless you make one of your own theirs is OK.
/forums/images/graemlins/smirk.gif
/ Pat's Easy Change - B7800 #8
/ Pat's Easy Change - B7800 #9
The objective is to keep the lower 3ph arms at the same distance apart and from swinging around wildly.... so, I use a bungee cord to hold them together and set the links for the right distance apart... works for me and the bungee cord flexes around when needed.
/ Pat's Easy Change - B7800 #10
Hey,
You guys are the champs -- I'm gonna order a set! /forums/images/graemlins/smile.gif
Thanks again,
mlg
Hey,
Thanks again,
mlg
/ Pat's Easy Change - B7800 #13
Sorry to catch this post so late, but I've had a set on my 7800 for well over a year. Best investment I made. They were well made, installed easy, and did just what they said they would do.
Only suggestion I might make is that you may need a longer top link. I haven't replaced mine yet, but I think I am on the last two or three threads.
/ Pat's Easy Change - B7800 #14
Hey Dave,
That's great stuff. Thanks again, to all, for the excellent input.
(I cannot remember why, but when I first joined TBN, I thought the PECS was a great idea -- I ran right out and measured my lift arms and decided "not" for the B7800. Thanks again for all you B7800 owners' specific help with this!)
I guess I'll head down to TSC for another top-link. Can do!
One nice feature: as I understand it, the PECS puts the implement a little further back. I borrowed my buddy's roto-tiller this past weekend -- it was right up to the ends of the PTO shaft. A few inches would have helped - immensely!
OTOH, the KK 60" Shredder may make the front a little light... If so, I guess I'll need the FEL. Hmmm... We'll see!
Be cool, /forums/images/graemlins/cool.gif
mlg
Hey Dave,
mlg
/ Pat's Easy Change - B7800 #17
can you post some pics of PEC and tell me where I can get one..........
/ Pat's Easy Change - B7800 #18
/ Pat's Easy Change - B7800 #19
Here's the link to the site for the Pats Easy Change, he's an advertizer here also, and I've attached a pic of a set on my BX 2200, hope it helps.
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
2005 JLG G6-42A Telehandler (A62613)
2005 JLG G6-42A...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
1996 MACK MIXER (A65643)
1996 MACK MIXER...
Rigid Pipe Threader & Pipe Stand (A62613)
Rigid Pipe...
