patching a tube ?
/ patching a tube ? #1
firemanpat2910
Platinum Member
Havana Fla
Ford 2910II
I had to take the tractor in to get a rear tire fixed. less than180 hours a new Massey 50 hp. had a peice of ground wire off a power pole stuck in it. tire was water filled and I dont mind the repair charge, but was wondering, the shop didnt even look at the tube to see if it was fixable, said the patch wouldnt work on a wet tube. @ 49 bucks for a tube, I wonder if anyone has experienced patches not working because of water? like i said over all not as bad as it could have been. I took them the tractor, repair was done while I waited. so $100.00 bucks, a few hours of time spent. Oh and I took my pops into town with me, so that cost me a breakfast bill :)
and on the plus side, after watching them do the repair, I might go price a set of tire spoons.
/ patching a tube ? #2
You need to find a new tire place! I patch mine that have had water in them. Its a bit time consuming to get enough water out to remove the tube from the tire but after that its just like fixing a dry tube. Im guessing they probaly cut it with a pocket knife to let the water out for removal to save time, i have been tempted to do this myself.
/ patching a tube ? #3
I have seen wet tubes patched and have patched several myself. I would say they probably didn't want to take the time to do the work and just sell you a new tube. Could also be if they patched they might not have stood behind their work. But for a tractor with less than 180 hours tube should be like new. By the time the shop took the time to patch your tube you were probably cheaper buying a new one.
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2021 PC210L Komatsu Hydraulic Excavator (A64553)
2021 PC210L...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
