Pasture Aeration
/ Pasture Aeration #1
treekatie
How much would you charge to aerate 20 acres of coastal bermuda?
/ Pasture Aeration
And what type of aerators do some of you like the best (water filled, brands, etc.)
/ Pasture Aeration #3
I have had my eye on this one at local dealer $5995 airway.jpg 8'airway
/ Pasture Aeration #5
Call me crazy ... Aeriation is good not until you brake the hard pan ???
/ Pasture Aeration #6
Cantoo, would you mind sharing the brand name of the aerator in the picture you supplied? Thanks
/ Pasture Aeration #7
Aeration needs to reach the root zone. We use core aerators (as above) for our lawns at the state parks. They help with root growth. Not being able to use pesticides or fertilizer, this process is our best bet for healthy sod.
/ Pasture Aeration #8
The green ones I think are Ryan brand aerators. The last 2 that I sold went to North Carolina. I had a couple of these too.
Around here farmers are using aerators in front of and behind liquid manure spreaders to aid in getting it into the soil instead of running off.
/ Pasture Aeration #9
I have a tow behind Ryan lawn aerator that has the same weight disks. So I can confirm you're correct. I didn't know Ryan made a 3 point aerator before. Having the disks rotate independently makes turning easier. The spoons are replaceable but not cheap.
/ Pasture Aeration
What about how much to charge per acre? And Jim you right that's WAY out of my price range, and I don't even see a price!
/ Pasture Aeration #13
I rent a core / spade unit from the local Kubota dealer. It runs about $160 per day. I charge by the hour for the tractor with one hour move-on / four hour minimum and split the rental cost. Sometimes I drop the move-on charge if its close. I always try to put together at least a couple jobs at a time to make it a day.
Brushogging runs form $30-$35 per acre around here. I charge $35 for existing customers and $50 an hour for new fields. I figure 1.5 acres per hour and aerating takes about the same time as shredding if that helps.
/ Pasture Aeration #14
For that many acres, you would be better to buy an old one if you can't rent one. RD rancher is right on the time being close to bush hogging but fuel usage and the chance of damaging the machine would be way less so adjust your price accordingly.
They also make tow behind ones that have a hand operated hydraulic pump to raise and lower them, depending on your property type if you don't have a tractor you could tow it with a truck.
The aerator type are pricy, the one I had was the slicer style and I wasn't impressed with it. 4" wide and tuff looking but everything worked, bought for $500. Sold it for more.
/ Pasture Aeration
OK so this is what I ended up doing. He wants about a 3 acre tract disced up for a garden. $325 for that. The other 20 acres of his place he wants aerated, I found a used aerator that needs some welding repairs for around $600. So I'd end up starting off almost $300 in the hole with an unknown piece of equipment I may never end up using again.
Told him that the best I could do is straighten up my discs and aerate it with those for $25 an acre. That's $500, but if he wants me to do both I'd do it for $800 even. We'll see. Does that sound reasonable? I don't think I can do it for much less.
/ Pasture Aeration #16
If you can do it in a day or even two it sounds pretty good. $800 cash sounds even better.
Depending on what type of aerator that is the price sounds good. I have a handful of customers that I aerate for twice a year, so purchasing one that sits for 350 days a year isn't worth it for me.
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
(3) 3 1/2" X 36" HYD CYLINDERS (A64280)
(3) 3 1/2" X 36"...
Caterpillar TL1055D (A62177)
Caterpillar...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
