Parts washer
/ Parts washer #1
Bsavulis
Putnam, Connecticut
Kioti CK25
Just picked up a HF parts washer. The 20gal tub with a pump. What do you guys use in your washers? I was going to get K1 kerosene, or just diesel. Any thoughts?
Thanks
Brian
/ Parts washer #2
Thanks
Brian
I believe those pumps are only for water based cleaners
/ Parts washer #3
Yes, do check the specs for your pump. It may not handle hydrocarbon solvents. What you use will depend on what you're cleaning and whether it will be painted afterward. K1 and diesel are way too "oily" for my liking. You'll have to wash the parts after cleaning if you intend to paint them. :rolleyes:
I used to use Graymills Regular Agitene solvent, but it got so pricy I started mixing my own. I use a mix of 90/10 naphtha and paint thinner (mineral spirits). The paint thinner raises the flash temperature without making it too oily or leaving a residue. Even that's getting expensive these days. I've been using that in an old Graymills drum mount cleaner for years.
/ Parts washer #6
Let your pocketbook decide.
  • 11% OFF
    B'laster Parts Washer Solvent. 11% OFF.
    $114.04$128
    favicon-tbn
    Amazon.com - Seller & more
    Free delivery
    4.5(31)
  • 20% OFF
    Crc Parts Washer Solvent 05067. 20% OFF.
    $123.99$155
    favicon-tbn
    Advance Auto Parts & more
    Get it by May 2 (Free)
    4.1(20)
  • Summit Racing Parts Washer Degreaser SUM-941245-1.
    $12.99
    favicon-tbn
    Summit Racing
  • Zep Professional Parts Washer Solvent.
    $149.99
    favicon-tbn
    Free delivery
  • LOW PRICE
    Bio-Circle Parts Washer Cleaning Solution 55A107. Low price.
    $207.78Usually $296
    favicon-tbn
    coxtool.com & more
    Free delivery on $500+
  • Graymills Parts CLEANERS/WASHERS-SOLVENT.
    $142.95
    favicon-tbn
    Grainger Industrial Supply & more
/ Parts washer #7
I'm running Stoddard in mine. Many years ago there was a Shell distributor up in Woodburn that had it on a pump for like $1.53 a gallon. Took two 15 gallon plastic drums up. Wish that still existed.
/ Parts washer #8
Diesel leaves an oily film behind, I don't want that on some parts that I wash.
I have mineral spirits in mine.
SR
/ Parts washer #11
Stoddard solvent or paint thinner.
Stoddard solvent is basically dry cleaning solution aka gasoline and de-greasing soap.
The formula is linked to heavy cancer progression, so use it wisely.
I only use Seafoam or Simple Green in my HF ultrasonic cleaner.
/ Parts washer #12
Found that mineral spirits (aka paint thinner) followed by straight Simple Green (biodegradable) makes excellent cleaner IF you don't have "parts washer"...
/ Parts washer #13
The TS solvent is all Ive used: PCS1000
It cleans well and no
problems with the pump..
/ Parts washer #14
PSC 1000 works great, I have used it for years without problem in the small 3.5 gal HF bench top parts washer (they don't seem to sell that anymore but you can still get one from other sources like Amazon)
Just as an FYI I added a SS band clamp to hold the filter screen in tight originally it was just a press fit and came loose
/ Parts washer #15
I haven’t bought any in awhile.. I buy 2 & 3 pails at a time to keep my tank topped off..
My TS store never have/had it in stock so I’d order it online and have it delivered to the store and drive to pick it up..
Are u for sure they stopped selling it.??
As far as the filter goes, I took a whole Scotch Brite pad and took 4 “bread ties” (wire) and weaved it to the OUTSIDE of the filter box..
That way I could catch anything that might make it thru to the inside filter..
/ Parts washer #16
I have enough trouble getting rid of used oil and UTF, how do you dispose of the used solvent ? Safety Kleen ?
/ Parts washer #17
Interesting question. Here are others wrestling with the same problem.
And the last one. Look at the costs of having a parts cleaner.
/ Parts washer #19
Idk if it’s the formula or what but the solids seem to collect on the bottom of the tank and don’t stay suspended, making for easy cleaning..
And yes, it does evaporate..
My washer has a lid and I keep it closed unless I’m using it.. AND I went around the inside seam of the lid with door/window weatherstripping.. THAT slowed the evaporation process down A LOT…
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2009 FORD E350...
