Parts cleaner solution
/ Parts cleaner solution #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Morning. A buddy just gave me his shop parts cleaner that he used kerosene in.I've used kerosene for years to clean greasy parts but is there something newer or better or safer on the market for these parts cleaning machines?. What do you guys use now?.
/ Parts cleaner solution #2
if you are looking for a degreaser, there is some purple stuff(i forget the name at the moment) that is pretty wicked. I know it will make your skin peel pretty quick if you don't dilute it or wear gloves.:D
/ Parts cleaner solution #3
I use low low odor mineral spirits from sherwin williams. In the 5 gallon can, it runs under $6.00 a gallon.
/ Parts cleaner solution #4
Kero is a pretty good cleaner.. I sometimes use diesel or mineral spirits.
While I like the water based ones..like simple green / purple stuff.. I usually only use those in temp buckets.. not the main washer.
soundguy
/ Parts cleaner solution #5
I picked up a gallon jug of some parts degreaser at Harbor Frieght. You dilute it with water. It works really great for my chainsaw chains. I soak them in a 50/50 solution in my cleaner can. Then take them out and hit them with a brush. It really works to get the gummed up bar oil and pitch out of the chains. After the chain gets sharpened then I drop them in a solution of old used motor oil and a bit of kerosene. That relubricates the chain and keeps them from rusting.
Thanks for the replies. Looking for a non flammable (it's right in there with welding machines and a propane furnace), non toxic solution. Simple green is water based but they recommend non metal parts washers in a 1.1 ratio. Might go that route and let it rust...tradeoff.
/ Parts cleaner solution #7
If you get by Harbor freight check that stuff out. It isn't flammable. If you want to rust proof it maybe spray it down with WD40 or something. Atomizing it from a spray can might be volatile for awhile. You can buy WD40 in liquid can so that you can rub it on or brush it possibly.
/ Parts cleaner solution #8
I'm pretty sure mineral spirits (and similar ) is simply combustable and not flamable.. someone got a chart handy to double check me on this?
soundguy
/ Parts cleaner solution #9
Lots of folks used "varsol" in parts cleaners. The outfit where I buy my propane still has a big tank and its sold by the gallon. Something else you might check is the Safety Kleen website. Check their msds sheets for the parts cleaners they have in shops all over the country. The ingredients might hel[p you find something.
/ Parts cleaner solution #11
I use 1 gallon of Gunk Degreaser mixed with 5 gallons of Kero in my parts washer. Works great. Not non-flammable though.
PALLET WITH 3 ELECTRIC CHAIN HOISTS AND ONE MANUAL CHAIN FALL OUTBOARD MERCURY PARTS MOTOR (A66738)
PALLET WITH 3...
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
TAG 35" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 35" QUICK...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
