part troubles
/ part troubles #11
my dealer did pull a line off of a 45dkhse, no cab, but it doesn't fit the 50dkhse cab. i was hoping someone from kioti, not a dealer, would read my post and give me some feedback on part orders. i'm sure they are lurking but affraid to comment. hoping we can figure something out today for a temp. fix. thanks.
Why woud they be afraid?
/ part troubles
the line that is broke is a return line from the cooler to filter housing. its not high pressure (?), dealer is taking one off dk45hse no cab and cutting it and putting flex line in middle. hope it works. thanks for comments.
I would definitely fix (weld), rather than buy a new hard line if it is one of
the ones I think it is. As JOELD points out, a hydraulics shop should be
able to make one up for you, too.
I have had trouble with welding on some thin hydraulic tubing, as the
steel in the tubing chrystallizes near the weld boundary and is weak. An
all-new hardline, except for the banjo fitting, is a better solution probably.
I have used thicker tubing if welds are involved. Any tubing you weld
must be very clean of oil or the welds will be porous. Brazing won't have
that drawback. Don't rule out a flexible line either.
I have also noticed that some hardlines in my CK30 vibrate a lot at certain
engine RPMs...this can cause hardline metal fatigue. It may even be the
cause of the failure of many Kioti CK oil cooler connections. I secured
some of my hardlines with additional damped supports to cut down on the
vibrations. There was a thread about this a couple of years ago.
As for getting parts, it seems that tractor dealers in general stock very
little in terms of parts, other than filters, belts, and maybe hoses. Every
time I order anything from the various JD or Kubota places, my parts are
shipped from a warehouse...generally in 3 days. Usually, they are shipped
from the warehouse to the dealer, then to me. I have never had a
problem with that. Kioti is a different story, but I can not expect their
dealers to stock any more than the big boys stock. I do find their additional
charges to ship directly to me from the warehouse to be annoying, given
the scarcity of dealers. I admit that I have bought much less in terms of
parts from Kioti as the 3 machines I bought parts for were purchased new
and have been very reliable.
/ part troubles #13
wish i would have investigated more before my purchase.
That's nuts. Clearly you are just venting hoping it will bring a torrent of "I'm sorrys" from lurking Kioti parts suppliers.
Try this: go to your local Ford dealer and ask at the parts desk for a power mirror motor for a 2000 Crown Vic. Think they have them in stock? Right.
Bashing Kioti isn't the right answer.
/ part troubles #14
I can have a full set of engine valve springs for a Model "N" Waterloo Boy produced by John Deere in 1920's in a day if I pay extra and three days if I wait on their truck shipment at my John Deere dealer. Not many tractor manufactures can say that or support their products like that. I know on my Deere tractors I have never had to wait more than three days for parts and most of my stuff has some age on it.( I do too!) I have good luck with Agco supporting older tractors and Case IH as well. My New Holland hay equipment has been supported well also.
Kioti makes a great lookin tractor that has great fit and finish. It looks as good or better than some of main stream brands. They are still developing a logistic network that the others have had a hundred years or more to establish in the States. I admitt I would be frustrated waiting on a part, but I would also would of had some idea they are still a growing tractor brand in the states and there maybe some problems like this when I bought a Kioti. It does sound like you have a Great Dealer. There are a few Kiotis in my area and I have heard good things and we have a great dealer as well. :)
/ part troubles
kioti deserves all the bashing they can get. If they could at least say the part is in korea and will be on the next boat over, ok. But they won't even acknowledge my request of where the part is and when i can expect it. I understand that they don't have the parts distribution down yet, but thats there secondary problem, communication is there primary problem. so there "I'm venting" some more and I have reason. If I were "making" money with this tractor I would have traded it in already.
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F11JX133691 (A61165)
2018 Toyota Tundra...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2015 Jeep Compass SUV (A59231)
2015 Jeep Compass...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A59231)
2018 Regal 29OBX...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
