part troubles
/ part troubles #1
naples, id
dk50se hst
my fears of buying a kioti have come true. had a hard hyd. line split. can't fab a rubber one. was hoping to have part in 5 days (n.c. to idaho), nope. don't know when it will be in. so my dk50hse sits in neighbors pasture. thankfully i have a great dealer in post fallls/rathdrum (speciality tractor) and he had the line braised. will pick it up tomorrow and see if it works. kioti could make a bigger impact on tractor sales if they had a better parts distribution. one warehouse in country? wish i would have investigated more before my purchase.
/ part troubles #3
We do have a better parts distribution....It's
We as dealers can not stock all the parts it would put us out of business.
/ part troubles #4
I've had some long waits for Kubota and Deere parts in the past.
Tough to pass judgement on one part request.
Joel
/ part troubles
i'm not making my judgment on my part alone. have a friend whos dad bought a kioti and has had trouble with parts. i got the tractor running thanks to a great dealer. i don't expect dealers to stock all the parts. i understand inventories and the cost, but why doesn't kioti's warehouse have it, and why can't they give a ship date. i'm not saying all other manufactures are perfect and have the parts but they appear to do a better job.
/ part troubles
still no hyd. line. the repaired line split again. kioti can't give a ship date.
/ part troubles #8
Sorry to hear about the struggles. Not sure where it split, but until the new line comes can you go to dealer (any dealer, including some auto parts places or equipment places (heavy equipment)) and get a hydraulic line made up to splice in in the meantime??
Very frustrating when a new piece of equipment is down for the count.
I would think very rare that a new hard line lets go, I've not heard of this before.
Good luck,
Joel
PS> your dealer should be willing to pull from tractor on lot if available, my kawasaki dealer always did that for me any my brother when we were racing.
Joel
/ part troubles
my dealer did pull a line off of a 45dkhse, no cab, but it doesn't fit the 50dkhse cab. i was hoping someone from kioti, not a dealer, would read my post and give me some feedback on part orders. i'm sure they are lurking but affraid to comment. hoping we can figure something out today for a temp. fix. thanks.
Good luck,
Joel
Joel
/ part troubles #10
...hoping we can figure something out today for a temp. fix.
I would definitely fix (weld), rather than buy a new hard line if it is one of
the ones I think it is. As JOELD points out, a hydraulics shop should be
able to make one up for you, too.
I have had trouble with welding on some thin hydraulic tubing, as the
steel in the tubing chrystallizes near the weld boundary and is weak. An
all-new hardline, except for the banjo fitting, is a better solution probably.
I have used thicker tubing if welds are involved. Any tubing you weld
must be very clean of oil or the welds will be porous. Brazing won't have
that drawback. Don't rule out a flexible line either.
I have also noticed that some hardlines in my CK30 vibrate a lot at certain
engine RPMs...this can cause hardline metal fatigue. It may even be the
cause of the failure of many Kioti CK oil cooler connections. I secured
some of my hardlines with additional damped supports to cut down on the
vibrations. There was a thread about this a couple of years ago.
As for getting parts, it seems that tractor dealers in general stock very
little in terms of parts, other than filters, belts, and maybe hoses. Every
time I order anything from the various JD or Kubota places, my parts are
shipped from a warehouse...generally in 3 days. Usually, they are shipped
from the warehouse to the dealer, then to me. I have never had a
problem with that. Kioti is a different story, but I can not expect their
dealers to stock any more than the big boys stock. I do find their additional
charges to ship directly to me from the warehouse to be annoying, given
the scarcity of dealers. I admit that I have bought much less in terms of
parts from Kioti as the 3 machines I bought parts for were purchased new
and have been very reliable.
/ part troubles #11
Why woud they be afraid?
/ part troubles
the line that is broke is a return line from the cooler to filter housing. its not high pressure (?), dealer is taking one off dk45hse no cab and cutting it and putting flex line in middle. hope it works. thanks for comments.
/ part troubles #14
I can have a full set of engine valve springs for a Model "N" Waterloo Boy produced by John Deere in 1920's in a day if I pay extra and three days if I wait on their truck shipment at my John Deere dealer. Not many tractor manufactures can say that or support their products like that. I know on my Deere tractors I have never had to wait more than three days for parts and most of my stuff has some age on it.( I do too!) I have good luck with Agco supporting older tractors and Case IH as well. My New Holland hay equipment has been supported well also.
Kioti makes a great lookin tractor that has great fit and finish. It looks as good or better than some of main stream brands. They are still developing a logistic network that the others have had a hundred years or more to establish in the States. I admitt I would be frustrated waiting on a part, but I would also would of had some idea they are still a growing tractor brand in the states and there maybe some problems like this when I bought a Kioti. It does sound like you have a Great Dealer. There are a few Kiotis in my area and I have heard good things and we have a great dealer as well. :)
/ part troubles
kioti deserves all the bashing they can get. If they could at least say the part is in korea and will be on the next boat over, ok. But they won't even acknowledge my request of where the part is and when i can expect it. I understand that they don't have the parts distribution down yet, but thats there secondary problem, communication is there primary problem. so there "I'm venting" some more and I have reason. If I were "making" money with this tractor I would have traded it in already.
That's nuts. Clearly you are just venting hoping it will bring a torrent of "I'm sorrys" from lurking Kioti parts suppliers.
Try this: go to your local Ford dealer and ask at the parts desk for a power mirror motor for a 2000 Crown Vic. Think they have them in stock? Right.
Bashing Kioti isn't the right answer.
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
