PART MISSING FROM MTD SNOWBLOWER
/ PART MISSING FROM MTD SNOWBLOWER #1
Shameless1965
ontario canada
craftsman LT4000
Good Morning:
I have an 2 stage snow blower I am mounting to a lawn tractor.
There is a part missing form the "REAR IDLER BRACKET ASSEMBLY"
To be exact I am missing the "IDLER ENGAGEMENT BRACKET"
Please see attached pic, missing part is highlighted in yellow.
This part is not used when attached to a machine with electric pto, the previous owner did not need it for his machine and it got lost.
The snowblower is an MTD, model # 190-621 built in the 1990's
If you have this blower or have the part I would be in debt to you for supplying me with the dimensions................:thumbsup::thumbsup::thumbsup:
Thanks in advance
Hi Guys:
I have attached a pic of the entire assembly with the missing part highlighted in yellow.
/ PART MISSING FROM MTD SNOWBLOWER #3
Looks like a relatively easy thing to make - flat steel maybe 1/8" thick? Would be nice if you could find one, but... I always keep little cr*p like that for someday, but I realize many don't.
Jim
No one has replied yet.......:smiley_aafz:
I have a template made form light steel, just need to do some fine adjustments prior to fabrication out of 10 guage steel.
I was frustrated so I printed the image that I had attached to my first post.
I enlarged the picture as large as would fit on 8.5 X 11 paper via MS Paint.
I made the assumption that the drawing was to scale.
I then measured the control rod in the picture against the actual rod.
I scaled it up and made a template out of a piece of 20 guage steel I had laying around.
Need to run the engine to check if the tension is right and that step is done.
Thanks for the encouragement:):)
/ PART MISSING FROM MTD SNOWBLOWER #5
Do you by chance have a real picture of Idler spring locations. I have owners manual but can't tell exactly where they attach
thanks. MTD Model 190-621
2015 Chevrolet Tahoe SUV. (A64557)
2015 Chevrolet...
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
2021 CATERPILLAR 302.7D CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2022 SANY SY26U EXCAVATOR (A63276)
2022 SANY SY26U...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
