Parking brake lever extension
   / Parking brake lever extension #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
The parking brake lever was always a pain to reach down and set, especially after I put on an aftermarket seat that is 4" higher.
So, with material found laying around the shop, made up an extension. Now I can set it from just reaching to the dash.
It works much, much easier!
   / Parking brake lever extension #2
Looks professional 🤙
   / Parking brake lever extension #3
Very nice job. Unless I can shed a few pounds I may borrow that idea for the Kubota. On the L3200 I had, it was easy to push the brake with my right foot and use the toes of the left foot to lift the lever. On the L4240 the lever isn't as accessible with my left foot, and after a big breakfast it is sometimes not easy to reach:)
   / Parking brake lever extension #4
Yes. Great idea but on my L4150 there is a button on the end of the handle you have to push to release the brake.
   / Parking brake lever extension #5
Mine is spring-loaded and releases when I press the brake pedal. Looks like you need to wait for Version 2.0 :)
   / Parking brake lever extension #6
One of the best modifications I did to the Kubota B26. Brake on warning light too. Helps keep the peace between my wife and I using the tractor.
Looks good! Makes you wonder how much the manufacturers save by not adding that foot of steel!
   / Parking brake lever extension #8
Good job on the extension, looks factory almost. I'd like to know how difficult/complicated it was to add the light...I have a brake light on the Kioti dash, but guess they deemed that a luxury item...
   / Parking brake lever extension #9
Brake light for B26 was easy. Kubota already had a bracket with hole perfect for a universal motorcycle rear spring switch under the dash. Had to drill a small hole for the spring on the lever to link to the switch. Then find a key “on”hot wire for power. Lamp was LED trailer marker light.
   / Parking brake lever extension #10
Thank you.. I'm assuming you mean the rear switch that activates a motorcycle rear brake light?
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
John Deere 204L ABSOLUTE SALE (A56436)
John Deere 204L...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
