Parking Brake Alarm?
   / Parking Brake Alarm? #11
Had that same issue with leaving the parking brake on. Then it occurred to me - just drive it like a car. You never put your car in gear without stepping on the brake (which kicks my parking off). I already had the muscle memory, I just needed to apply it.
   / Parking Brake Alarm? #12
   / Parking Brake Alarm? #13
I agree with the others about NOT using the parking brake. Unless I have it on a trailer or something unusual is going on, don't use it. Drop the bucket, drop the 3-point if you have anything on it, etc.
When I do have to set the brake, I try to really set it tight! It's pretty noticeable if you really hammer it down -- not as likely to drive around with it dragging like I do if it's set lightly.
   / Parking Brake Alarm? #14
You wouldn't wire the buzzer to the brake lights, but to the 'Parking Brake is ON' indicator light on the dash.
   / Parking Brake Alarm? #15
The other good option is just until your turning brakes. At least on Kubotas the parking brake only holds down the inner brake & the pin between the brakes holds the other one. I can usually figure that after the 2nd or 3rd circle the tractor drives in when only 1 brake is on.
   / Parking Brake Alarm? #16
I use my parking brake often, if I don't want to drop the bucket or when I have something on back such as the tiller, which won't stop me from rolling. I always set it hard enough so that the tractor lets me know when it's on; i.e;, doesn't want to move. Otherwise what's the sense of using it?
   / Parking Brake Alarm? #19
Our Yanmar will not move with the parking brake
on.
willy
   / Parking Brake Alarm? #20
BAYSIDE TRI-CYCLE (A58374)
BAYSIDE TRI-CYCLE...
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
(NEW) SOUP KETTLE (A58374)
(NEW) SOUP KETTLE...
S/A Utility Trailer (A56858)
S/A Utility...
BEFCO DISC MOWER (A52708)
BEFCO DISC MOWER...
