PAretired
/ PAretired #1
PAretired
glen rock, pa
John Deere 445
I own a John Deere 445 w/ hydro trans. Current hour meter reading is only 1,300 hrs. When PTO is engaged ( mower deck ) the steering and reverse operation of transmission has become very difficult. Power steering is very heavy and difficult to turn wheel either forward or reverse and the speed of tractor in reverse is extremely slow / crawls in reverse. I had previously changed the hydro fluid and filter some ago and the fluid is clean and to proper level. Any suggestions as to a remedy before taking to dealer ( prefer not to ) that I can accomplish here at home ?
/ PAretired #2
Probably start by checking charge pump pressure. Could be pump weak or going out or internal leak
/ PAretired
Thanks for the quick reply. Not to sound stupid but how do you check the charge pump pressure ?
/ PAretired #4
Private message me your email and I'll shoot you some pics
/ PAretired
Sounds like more test equipment, etc. than I own. Just the average home owner. I hate the thought of taking back to JD. Do you think changing the oil and filter will help ?
Oil is still good color od red and full.
/ PAretired
Sorry, I forgot to say thank you for your relpies and help.
/ PAretired #9
With the attached info just about any auto repair facility should be able to do the pressure test, may be not as many options for the flow test.
/ PAretired #11
Yea if you have a hydraulic line place they will have all the fittings and stuff you need to perform the tests. It's good to have that stuff for a tractor owner that knows how to turn a couple wrenches !!
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
AR500 Coyote Target (A65640)
AR500 Coyote...
