Pallets in fields
   / Pallets in fields #362
I just noticed that you are located in New Jersey. Because we have not heard from the OP (Bob), it is your responsibility to make inquires as to the pallet formations.;)
Steve
Most fields in NJ have names. They are called parking lots. I will do what I can to bring this to a conclusion. If I knew where sparcs lived, I would check to be sure he is ok, then throttle him for leaving us hanging.
If I find the fields and see feet under the pallets, I'm outta there!
   / Pallets in fields #363
You will be happy to learn that I have figured out to monetize the contents of this thread.
I have developed a script that has been been purchased by the producers of Ancient Aliens which airs on the History Channel.
Some of you (well, actually all of you) neglected to copyright your material. Thus, that material is in the public domain and can be used without compensation.
Thank you and keep up the good work.;)
Steve
You might want to look into the provisions needed to copyright a work per the Berne Convention rules...
Aaron Z
   / Pallets in fields #364
That's the spirit!!:thumbsup:
Make sure that you take photos first.;)
Steve
   / Pallets in fields #365
That would be the "Ox-y-moron" faction.:D
Steve
uh ohhhh now I am offended, wait are you referring to me or someone else?
I will await your answer before continuing my sensitivity
   / Pallets in fields #366
Only you know whether "the shoe fits.";)
Steve
PS -- Scientific debate can become heated at times.:)
   / Pallets in fields #367
ok, I have size 13 feets, so I will assume the shoe wont fit :D
2000 Volvo Semi (A59814)
2000 Volvo Semi...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
