Pallets in fields
   / Pallets in fields #191
Maybe Sparc is on a deep cover mission to find out what really goes on those pallets.
   / Pallets in fields #193
I may have Cracked IT!!!! They are the first stage of the construction process for REALLY BIG birdhouses. (Eagles? The elusive NJ Condor!?!... the mind BOGGLES!!!!)
Source: Wooden Pallet Crafts = Birdhouse
Cut two wood plank sections measuring 6 inches long by 4 inches tall for the sides of the birdhouse. Cut two wood plank sections 4 inches long by 4 inches tall for the front and back of the birdhouse. Cut two wood planks slightly larger than the sides for the roof. Drill a hole in the middle of one side with a 2-inch wood spade drill bit. Glue sides, front and back together with wood glue forming a rectangle. Glue roof panels with edges perpendicular to each other, creating an inverted V shape for the roof. Dry according to instructions on the wood glue label. Paint your wooden pallet birdhouse. Run a line of wood glue on the top edge of each wall. Sit roof on top of the birdhouse, press down and allow glue to dry.
Read more: Wooden Pallet Crafts | eHow
What say you, Steve?
   / Pallets in fields #194
maybe tombstones? since Sparc went missing is there an additional set of pallets?
   / Pallets in fields #195
Bruce,;)
Your "Antipodean Avian Abode" theory cannot be dismissed out of hand.
1. The location of the pallets in New Jersey would be but a short flight to/from Lincoln Financial Field, the haunt of the Philadelphia Eagles (Philadelphia Eagles Team Page at NFL.com).
2. The timing of the pallet appearances on the landscape is roughly coincident with the migratory pattern of said congregation.
3. There is no number 3.
However, it strains credulity to think that Bob would not have noticed the inhabitants of the purported avian domiciles given the distinctive plumage of the aforementioned congregation.
Your theory is more plausible than some (e.g., Hayist, Drainist), but is less plausible than others (e.g., Alienist).
Steve
BTW -- How did the other Bruces do in their match against the Pommies?
   / Pallets in fields #196
It must be another evil plot by those cunning agents of that international organization of evil, KAOS. The pattern of the pallets, if processed through a top secret algorithm, seem to point directly to Bucharest. Coincidence? I think not! I'll report to Chief as soon as I can find Agent 99.
Maxwell Smart, Agent 86
  • windowslivewriterbusinessideastohelpyourmagazine-b841maxwell-smart2-thumb-470x480-1053301.jpg
   / Pallets in fields #197
Not to mention the playoffs?
   / Pallets in fields #199
Bruce,;)
Steve
I think Bruce's (?) mates are sticking it right up the Poms :cool2:
   / Pallets in fields #200
I have some fond memories of Agent 99!
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
John Deere 5103 (A53317)
John Deere 5103...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
