pallet forks
/ pallet forks #1
treesawer
I am building a fork implement for my tractors 3 point hook up. A widow friend who has 4 sets of used forks,lengths start at 36" & end at 53", most are in good shape & some are heavier duty than others some are rusty(not serious). My question is, what should I offer her for any 1 pair of the clip on type? I see new ones starting in the $300 range.
Treesawer /forums/images/graemlins/confused.gif
/ pallet forks #2
Half price of new is considered fair in my neck of the woods. At auction, you'll often pay a good bit more than that.
Mike
/ pallet forks
Ok, that's something to think about. I was thinking of offering 40-60% of a what new might cost me.
Treesawer
/ pallet forks #4
I hate to sound like Mr. Obvious here, but I'd suggest you just ask her what she wants for a pair of them. That's always a good starting point. /forums/images/graemlins/smile.gif If you feel her number is too far off the market for you to be comfortable you can always suggest a different number then.
/ pallet forks #5
Treesawer,
You might search for a post I started called "Post your pictures of forks". It has lots of pictures.
Mine are 3pt. I didn't build them to the CAT I quick hitch standard, so they don't fit my Speeco quick hitch. Bad mistake. My new loader (finished installing it today) has a bobtach type bucket mount. My next trick will be to rework my forks so the mount will work with a quick hitch and aso a bobtach. This way it can be quickly installed front or back.
I paid $125 for 48" very good condition forks from a man with a rrrreputation for selling things high. I think, however, that it is fair. If you don't buy them for $125 she probably will get $50 from someone who does not care about her. Good luck and post pictures.
Jim
/ pallet forks #6
I bought a pair of forks today at a salvage yard. $100.00 per fork and $50.00 for the mast where the forks mount.
/ pallet forks #7
Condition, length and heaviness of duty not withstanding, scrapyard price here is $100/pair. Some are in pretty good shape.
OkieG
/ pallet forks #8
At a large auction at the GM plant where I work they sold 4K electric walk behind forklifts and I got one for $100.
Itook the forks and platen to make a Q-T set for my SSL, used the 2.5"X8" side shift cylinder for my top link,4 125# steel flat plate weights and 4 180# LEAD flat plate weights.
I was going to go the mast and 3 pt but the SSL forks work MUCH better.
I've got some other parts (2 hydraulic pumps and the tire assemblies to take off yet ) to remove then sell the other 2500# to the scrap yard.
Do all the forks use the same size platen (mount)??
If so I would get 2 sets one long and one short so u can inter change them later.
I'd try for $50-75/ set and could go up.
/ pallet forks
Well I bartered my labor over at the widows place for a set of used 48" HD forks. Now I am building the frame works & will post photos when complete. Thanks to all who responded with advice.
treesawer /forums/images/graemlins/cool.gif
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
2023 Case TV380 (A62177)
2023 Case TV380...
MERRITT ALUMINUM HEADACHE RACK (A64277)
MERRITT ALUMINUM...
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
