Forks pallet forks
/ pallet forks #1
ford farm boy
Indiana
Mx5100,9N,ford 2000
I have a kubota mx5100 and it says in the loader book the lift capacity at pivot pin is 2440 lbs so is forks rated at 2500 lbs max good our should i go bigger?
The forks are 48" long and the price is $500. Is this price good ? They fit a bobcat.
/ pallet forks #2
I see no reason 2500lb forks wouldn't be fine. The manufacturer would build a safety margin into them, above and beyond their rated capacity.
/ pallet forks #3
I paid about $700 for 4000 lb QA forks. If you are just lifting, then the 2500 lb should be fine. I have dug out rocks and old concrete with mine and I think I would have bent them if they were any lighter.
/ pallet forks #4
Should be fine, $500 sounds like good deal to me.
/ pallet forks
Stonehaller has a good point I don't know that I would be digging with them But!
I have looked at the ones that go on a bucket but they scare me .Isn't there a chance that could damage the bucket and that's two feet or so further out there. I have seen in the forums the QA forks that doubled as a hay spare I like that and I may do that sometime .
And thanks for your reply's
832637 (A61166)
832637 (A61166)
84in. Fork Extensions (A61567)
84in. Fork...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
2016 Komatsu HM400-5 44 Ton Articulated Dump Truck (A60352)
2016 Komatsu...
2016 Deere 180G (A60462)
2016 Deere 180G...
iDrive TDS-2010H...
