Forks pallet forks
/ pallet forks #1
ford farm boy
Indiana
Mx5100,9N,ford 2000
I have a kubota mx5100 and it says in the loader book the lift capacity at pivot pin is 2440 lbs so is forks rated at 2500 lbs max good our should i go bigger?
The forks are 48" long and the price is $500. Is this price good ? They fit a bobcat.
/ pallet forks #2
I see no reason 2500lb forks wouldn't be fine. The manufacturer would build a safety margin into them, above and beyond their rated capacity.
/ pallet forks #3
I paid about $700 for 4000 lb QA forks. If you are just lifting, then the 2500 lb should be fine. I have dug out rocks and old concrete with mine and I think I would have bent them if they were any lighter.
/ pallet forks #4
Should be fine, $500 sounds like good deal to me.
/ pallet forks
Stonehaller has a good point I don't know that I would be digging with them But!
I have looked at the ones that go on a bucket but they scare me .Isn't there a chance that could damage the bucket and that's two feet or so further out there. I have seen in the forums the QA forks that doubled as a hay spare I like that and I may do that sometime .
And thanks for your reply's
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
John Deere 72" Bucket (A64912)
John Deere 72"...
Survey Kit (A64912)
Survey Kit (A64912)
Kubota L275 (A64911)
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2 Bundles of Hydraulic Hoses (A64912)
2 Bundles of...
